Old 03-11-2004, 12:40 PM   #1 (permalink)
Default How to retrive data from mysql database dynamically
Folks ,
I tried Dreamweaver MX 2004 to do it automatically, that coroupted my whole site..
So , can u plz write me one code for me , all i wanted is i have already stored data in the database , now what i want is to show that data in the web page dynamically, like say dynamic table !
can u u show me how and if possible plz give me a full php coding for retriving data from databse..
thanks
Flip like a butterfly, sting like a bee
Butterfly is offline
Old 03-11-2004, 10:26 PM   #2 (permalink)
maybe this site helps :
http://www.abdn.ac.uk/diss/webpack/f...ml#section19.5
ishaan is offline
Old 03-11-2004, 10:57 PM   #3 (permalink)
Version 2.0
Deep's Avatar
i had given you the code in your last post i suppose..
need to use the same code to fetch the records and display the stuff in while loop...
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 03-11-2004, 11:02 PM   #4 (permalink)
Well,
If i were damn expert in it i would have not post it in the froum...well yeah Deep u did post it last time , but u dinbt post it all , somne parts are blank, and thats a difficult for me to add..
never mind
thanks a lot
Old 04-11-2004, 01:06 AM   #5 (permalink)
Version 2.0
Deep's Avatar
<?php
mysql_connect ($host,$user,$pass);
mysql_connect_db ($database);
$sql = "SELECT id,image_path,image_description FROM pic";
$result = mysql_query ($sql);
while ($row = mysql_fetch_row($result))
$id = $row[0];
$image_path = $row[1];
$image_description = $row[2];
$show_stuff .= "<img src=\"$image_path\">
$image_description";
// ^^^ this will store all the values of table inside $show_stuff ^^^
echo $show_stuff;
all done...
this is just basic..you need to customize it and add into your code according to your needs...
Regards
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 04-11-2004, 10:11 AM   #6 (permalink)
is it work if v dont have sql server connection in our web site?
deeeeeeeep?
~Think Globally... Act Locally......!!!~
prakashaka is offline
Old 04-11-2004, 10:13 AM   #7 (permalink)
Version 2.0
Deep's Avatar
you need mysql server for that...
connection you have to make it using the code i specified about...
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 04-11-2004, 04:18 PM   #8 (permalink)
Hellow Friends ,
This is the code am trying : have a look am getting error, if u all can fixed it up for me :
am getting error on this line : Parse error: parse error in c:\web\test.php on line 12
<html><body>
$host = "localhost";
$user = "root";
$pass = "";
$dbname = "karmas";
$connection = mysql_connect($host,$user,$pass) or die (mysql_errno().": ".mysql_error()."
mysql_select_db($dbname)
$sql = "SELECT ID,logo,Description FROM client";
$ID = $row[0];
$logo = $row[1];
$Description = $row[2];
echo $show_stuff;
</body></html>
My Table structure (karmas)
¦ID¦logo¦Description¦
($sql = "SELECT ID,logo,Description FROM client"; )
Old 04-11-2004, 05:07 PM   #9 (permalink)
Version 2.0
Deep's Avatar
should be
mysql_select_db($dbname) ;
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 04-11-2004, 05:30 PM   #10 (permalink)
Thanks Deep,
It finally worked , i like it ,...... something not yet arranged ..
cant the data be in dynamic table , so that what ever i retrive it from the datbase it directly show it in table in the browser ..
Let me know more
thnaks
