Old 12-03-2006, 06:55 PM   #1 (permalink)
nix
Senior Member
nix's Avatar
Default music in radio better than cd
hi,
i listen to radio everyday. I have a music collection in which most of the songs in my MP3 cd are also played in radio( radio city 91 FM). but the same songs in radio sound much better. In my collection, either the bass is too much or the vocals are too loud. they're just not right. most of the songs are this way. i've tried to adjust the bass and treble/middle settings on my hifi but still it doesnt sound right. radio on the same system sounds much better. i d/led those songs thru limewire. how to fix this?
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 15-03-2006, 12:39 PM   #2 (permalink)
nix
Senior Member
nix's Avatar
Default hi
c'mon guys i'm dyinghere...i need a solution for this...some songs realy dont sound good and its really frustrating..friends think, think...
nix is offline
Old 15-03-2006, 01:05 PM   #3 (permalink)
True Geek's Avatar
U must be having SONY i guess
True Geek is offline
Old 15-03-2006, 03:44 PM   #4 (permalink)
your mp3s are pirated, maybe
A man needs a certain amount of madness to cut the rope and set him free...
mvishnu is offline
Old 15-03-2006, 03:59 PM   #5 (permalink)
yrana2002's Avatar
Thats always going to be the case. You see, mp3 is a compressed format of a audio streaming.
Compressed means there's surely going to be a loss of quality. Its quality depends on how big the mp3 file is.
A 4MB file will be of lower quality than 8MB mp3.
If you're talking about internet radio, then yes, the quality seems just as original.
So, if you're ripping any music cds & dont want to compromize on quality, keep its size bigger or choose another format such as .wav
Savvy
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 15-03-2006, 05:13 PM   #6 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
man one thing abt mp3's higher bit rate higher quality higher size.check ur songs bit rate.128 is normal ok type.192 is nice.320 vbr is gr8.the radio guys buy original cd's and they play wav which are lossless!!so they will always sound good!!got it?
romeo_8693 is offline
Old 15-03-2006, 10:20 PM   #7 (permalink)
nix
Senior Member
nix's Avatar
thnx...
nix is offline
Old 16-03-2006, 12:25 AM   #8 (permalink)
Even these guys have better system which tunes the sound to give a crisp output...You can't compare your Car audio to Radio 91 FM's system dude...
...:::b@dma@$h:::...
codeash is offline
Old 16-03-2006, 02:38 AM   #9 (permalink)
El mooooo
eddie's Avatar
There can be 'n' number of reasons here. Severe compression of MP3s, mp3 player not using optimal equalizer settings, not very good sound card, not very good speakers connected to PC etc. etc.
eddie is offline
Old 16-03-2006, 08:18 AM   #10 (permalink)
i'd blame the compression. I have few mp3 files that sound better than the original cd.
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
