Old 12-03-2006, 06:01 AM   #1 (permalink)
lazy bone
Default xvid files -no play
I have recently downloaded a dvd-rip of a film.
It contains 1 sample file , & 2nd folder containing files numbering 001 to 049 (all with size of 14 mb) and there is file .sfv .
now, the sample file is playable, when i open the file 001 by right clicking on it , it shows me windows prompt where 2 options (use webservice to open or select the programme ) , I choose VLC to play it. The file played successfully. Now, whenever I try to open othere files from 002 to 049 , VLC can't play them.
I have K-lite codec so there won't any issue for codecs, I want to know that how to play this files ?
if these are numbered files , do they require some kind joining ?
tell me as I have no experience with such dvd rip . any 1 who has such ans plz give me ans , waiting for replys.
multi is offline
Old 12-03-2006, 04:19 PM   #2 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Go To
www.xvid.org
I am not master but i suggest you that,
to play diffrent media files,use their official software.
Orionz is offline
Old 12-03-2006, 04:46 PM   #3 (permalink)
slugger's Avatar
Default Re: xvid files -no play
wat u have there r files with extension 001 to 049 and not names 001 to 049. since there is a *.sfv file it means dat these files have been split most likely wit WinRAR, as dey r used 2 check split file integrity. So in order to rejoin dem u need to use WinRAR.
http://www.rarlab.com/rar/wrar351.exe
Even after joining the files if they do not play make sure dat u had selected intallation of the XviD codec form the K-Lite Mega Codec pack
http://web.volftp.tiscali.it/pub/pc/...lmcodec151.exe
slugger is offline
