Old 11-03-2006, 07:07 PM   #1 (permalink)
Default How do I know my ip is protected by NAT or what??
I am having dataone. I want to know using some software whether my IP is NAT enabled IP or what.
Please suggest some software to check for NAT..
nawaz123 is offline
Old 11-03-2006, 07:33 PM   #2 (permalink)
Let the music play.....
djmykey's Avatar
NAT might take place actually I also wanted to try it out but I dont have a comp worthy of running Win 2003 server so dint try it. But if u use masquerading it might work. Dunno anything after that.
djmykey is offline
Old 11-03-2006, 10:27 PM   #3 (permalink)
yrana2002's Avatar
No need of any software for this,
if you have dataone,then:
1. Type 192.168.1.1 in your Internet browser
2. Type admin in both username & password(default)
3. In the left column, click on NAT
4. See whether it is enabled or not..( you can enable or disable it yourself )
Savvy
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
