Old 11-03-2006, 08:10 AM   #1 (permalink)
maharajadhiraj's Avatar
Default what are mdf and msf files?
I just downloaded NBA Live 2006. The files are in the form of MDS & MDF :roll: :roll: files. How do i run them?????
maharajadhiraj is offline
Old 11-03-2006, 08:33 AM   #2 (permalink)
nishant_nms's Avatar
OK they are CD image files like iso, cue/bin. Use demon tools to mount them or alcohol to burn them. MDS has the details of the image and MDF has the contents
nishant_nms is offline
Old 11-03-2006, 11:32 AM   #3 (permalink)
Dreaming Future
kin.vachhani's Avatar
nishant_nms is right its basically an image of cd or either dvd....
u can use alcohol 120% to use those images ..... its good.....
World without Computer is like a man without Brain.....
kin.vachhani is offline
Old 13-03-2006, 12:16 PM   #4 (permalink)
parthbarot's Avatar
alcohol 120% is the best man...
supports all kind a images and fast and small...
Regards,
Parth.
see tutorial on alcohol on my blog
http://www.blogcharm.com/parthbarot
www.techlads.com
Paarth.
parthbarot is offline
