Old 10-03-2006, 06:40 PM   #1 (permalink)
Default error while shutdown
hi
i receive a 2 errors while shutdown
1. ccapp.exe
for it i have tried installing norton again and also a update of windows security alert but its still there,
2. explorer.exe
please help
thanks in advance
the world is not enough
mannu143 is offline
Old 10-03-2006, 06:49 PM   #2 (permalink)
nach p's Avatar
I think both files are eiter corruoted or infectd .
Just run sfc command and restore that corrupted file.
Or u can replace those files from the setup CD's to the
destination folder.
Btw which OS do u use and avoid Norton if possible .
nach p is offline
Old 10-03-2006, 07:10 PM   #3 (permalink)
Default reply
i use win xp media center edition with service pack 2,
please explain how to solve this problem.
mannu143 is offline
Old 10-03-2006, 07:46 PM   #4 (permalink)
nach p's Avatar
If u have a cd of Windows Xp media Centre edition with SP2 then just copy ccapp.exe and explorer.exe from i386 folder and replace it with new files. Just make search for the path in windows for that files.
Or u can boot from cd and run setup and just choose repair (R) option instead of new installation.
nach p is offline
Old 10-03-2006, 09:08 PM   #5 (permalink)
try for shutdown /p
or check out command this will work
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 10-03-2006, 10:45 PM   #6 (permalink)
destination folder.
I had used Norton for years and very often used to have shut down problems. Finally changed to Avast and no more problems now. And it is free.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 11-03-2006, 03:38 AM   #7 (permalink)
::vicky::'s Avatar
first u scan ur system with antivirus like quick heal and spyware doctor
::vicky:: is offline
