10-03-2006, 06:21 PM
Cool as a CUCUMBAR ! ! !
Dreamweaver 8 ! ! !
Just upgraded & Cannot set page size 2 800 * 600 ... how 2 set it ???
statusbar shows 995*496 bt clicking on it shows a popup where all sizes r present bt greyed out ...
whot 2 do ???
13-03-2006, 03:54 PM
plz plz plz ... gimme a solution ...
... W H O T ...
13-03-2006, 04:18 PM
Rubik's Uncle!!
Sorry dude i only have the full install version. Try with a clean installation. though remember to backup your settings etc.
13-03-2006, 05:40 PM
i have the full version ... plz ... read my ? ...
... W H O T ...
13-03-2006, 05:58 PM
Rubik's Uncle!!
Resize the child window. now you can see the greyed out options.You can see the ruller above the child window . so you can always know the size. You can just keep all the content within the border.
14-03-2006, 01:27 AM
El mooooo
Why don't you try deleting the Macromedia directory from the "Application Data" folder in your profile directory? If you don't have any of your important files in there (like some website pages etc.) then it should be entirely safe.
14-03-2006, 10:40 AM
Commander in Chief
@eddie - how is that supposed to help ? It will then ask to repair the installation thus. I dont think a silly problem like that is an installation error is it ?
the options are greyed out for me too, but dragging and enlarging the design window to a desired size changes the screen area of the page...
Harsh J
www.harshj.com
14-03-2006, 10:53 AM
El mooooo
Repair the installation? Why will it need to repair the installation and where did I say that it is an installation error? Did you try to read the solution carefully before commenting? I am not talking about deleting the data from Program Files. I am talking about "C:/Documents and settings/<user name>/Application Data". That is your profile folder and holds various type of settings for programs that you use. If you delete the "Macromedia" folder in it, you reset the program to its default factory settings. There is no harm in deleting these folders. It just removes all the settings that you screwed and all the settings that were made by you deliberately. Dreamweaver will create this folder again with default settings on its next run.
14-03-2006, 11:16 AM
Commander in Chief
I had both flash and dreamweaver and i tried it, now it asks me to repair the installations as some files are missing... perhaps its a problem with me alone... sorry for that.
Harsh J
www.harshj.com
14-03-2006, 11:50 AM
its a simple ? ... how do u set page size for ur webpage in dreamweaver 8 ???
ppl using it help ...
... W H O T ...
14-03-2006, 11:55 AM
Commander in Chief
have u even tried resizing like charangk suggested ? its the simplest way :roll:
Harsh J
www.harshj.com
14-03-2006, 06:57 PM
am not talking abt resizing bt page setting 4 website ...
... W H O T ...
23-03-2006, 11:18 AM
hey designer or programmers or ppl using dreamvear ...
how do u decide oe create page size ???
... W H O T ...
23-03-2006, 11:24 AM
Commander in Chief
W8, lets clear ur doubt a bit...
Do u wanna change the page's resolution to a specific size like 800x600 etc for optimisation or do u want something else?
Harsh J
www.harshj.com
23-03-2006, 11:54 AM
Beware of the innocent
I really couldn't understand what the discussion is about. HTML, to my understanding doesn't relate to the concept of resizing. Of course in Dreamweaver all those resolution stuff would at the most change the window size. See, i don't use dreamweaver, i prefer to hard code. But in all my knowledge html is not picky about resolution. The best you can do to set a size is to create a table with hardcoded width as 800 px or something.
Dunno if it helps. I have got a dreamweaver demo CD software somewhere. I will try to dust it and find out.
Good luck axe
23-03-2006, 04:12 PM
9437077259
I too am facing the same problem. Lets see if some one can really help.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
23-03-2006, 11:12 PM
check this link http://curriculumwebs.com/BuildingCu...ebs/images.htm
An extract:
Look at the status bar of the page editing window. (This is the bar at the bottom of the window.) It should look something like this:
<img>
The leftmost information represents the HTML tags that apply to the current context.
The next piece of information is the size of the editing window. This is useful if you are designing your page for a certain size or resolution of monitor. (The example here is 689 pixels by 331 pixels, which will fit onto an 800 x 600 monitor resolution but not 640 x 480.) You can click the down-arrow here and choose from a number of preset sizes to see how your page is likely to format at each of these resolutions.
-- So that is the normal way of doing it.
Hey just got an idea. Is the editor window maximized? If it is try to restore it and check the popup
23-03-2006, 11:17 PM
Commander in Chief
yes it remains greyed out but when u manually resize the work area it changes... thats what charan's been telling all these long...
Harsh J
www.harshj.com
23-03-2006, 11:37 PM
#19 (permalink)
well, axe has to acknowledge that it worked, what do you say axe. Did it work?
27-03-2006, 12:20 PM
#20 (permalink)
thanx 4 those replies ...
bt thats adjusting the screen size only ... i just wanted 2 create a simple site of size 800*600 p resolution ... as v can set this size in flash 5 or mx cant v do the same thing in dreamweaver ???
or is it the tab @ statusbar is just 2 adjust any page according 2 ur monitor screen size & NOT webpage size ???
... W H O T ...
28-03-2006, 01:15 PM
#21 (permalink)
You are getting the idea. That size is the dreamweaver's page editor size and is there only to let you resize that window. It is grayed out probably because you have maximized DW window. You can change the value manually by resizing the window.
To make the entire webpage the size you want, put the entire content (excluding the bady tag) inside a div and set it's style to "width:500px;text-align:center;", for example.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
28-03-2006, 03:33 PM
#22 (permalink)
If you 're using tableless layout (using DIVs and CSS) set the main DIV size to 790px or so. and set the styles as align-right:auto; align-left:auto.(to centralize the page on any resolution)
Or if u r using Tables, just give 100% as it will keep growing with browser window size.
a sample css would be
#main-content {
width: 790px;
margin-right: auto;
margin-left: auto;
and your html may look like
<body>
<div id=main-content>
all othe items comes under this div
</div>
</body>
And if it is table
<table width=100%>
</table>
And always try to use the DIV instead of table for designing. Because it is faster and efficient.
Search this Thread |
