Old 02-11-2004, 06:53 PM   #1 (permalink)
Default LSASS.EXE Errer And 60 Sec. Restart...!! Help..!!
My dear friends
I have w32.sasser.worm..!!
i have win2000 pro os.
i install patch for this virus..!!
and run norton removal tool ...!!
and norton 2003 Pro with latest update..!!
is scan with all antivirus...!! with latest update..!!
but still problem of Lsass.exe application error..!!
Errer is
Lsass.exe ApplicationError
The Instruction at "0x77f83378" referenced memory at "0x00000004".
The memory could not be "read".
Click on ok to terminate the program
IS IT NEW virus other then sasser.worm..!@@
how can i remove this error...!!
Have A Nice Day....!!
pr@k@sh is offline
Old 02-11-2004, 07:09 PM   #2 (permalink)
vysakh's Avatar
http://securityresponse.symantec.com...r/FxSasser.exe
is this the removal tool that u have downloaded??
else try it
Incompatible message format
vysakh is offline
Old 02-11-2004, 07:23 PM   #3 (permalink)
i already use this fix exe but problem is same...!!
it say that no virus is found but problem is same..!!
pr@k@sh is offline
Old 02-11-2004, 07:46 PM   #4 (permalink)
i also had the problem
i turned the 'Internet Connection Firewall' of windows xp on for all my dialup connections...now it doesnt happen
u can do this from the properties of the connection, under the ADVANCED tab
TIP: incase it does happen, go to START>RUN and type
shutdown -a
this will abort the shutdown....but ur pc wont run all apps properly so better to restart after finishing ur work.
ishaan is offline
Old 02-11-2004, 11:27 PM   #5 (permalink)
Don't use windows' default firewall.
Use Zonealarm it's best.
Don\'t assume. It makes an ASS out of U and ME
tushar_novice is offline
Old 02-11-2004, 11:40 PM   #6 (permalink)
ice
Hes using win2k, im not sure if it has its own firewall!
ice
ice is offline
Old 03-11-2004, 01:17 AM   #7 (permalink)
whichever other firewall u use but you must keep on the windoes firewall on to solve this problem.
superuser is offline
Old 03-11-2004, 01:29 AM   #8 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Have you installed SP2 for W2k .. ?
http://support.microsoft.com/kb/282522/EN-US/
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 03-11-2004, 10:18 AM   #9 (permalink)
Thanks to all
but i m using win2000 pro and in that
shutdown -a or shutdown -i
is now working ...!!
but in win 2000 pro for this solution is change the time or chage the date of 1 Day last..!! so it give the time 24 hrs. ...!!
and
in my sys follow is installed
Win 2000 Pro
service Pack 4
i also install w32.sasser.worm and w32.blaster.worm patch form microsoft
even i run fixblas and fixsasser exe from norton web site...!!
norton 2003 pro with latest update..!!
I have a Lan cable through Inter net...!!
so when i remove lan cable then it's working fine..!!
but when i insert cable then problem is comming..!!
i think it's a new virus..!!
but how to solve this problem...??
pr@k@sh is offline
Old 03-11-2004, 10:20 AM   #10 (permalink)
is it necessary that
i already install win 2000 pro sevice pack 4
so i have to install service pack 2 ??
is it necessary....??
pr@k@sh is offline
Old 03-11-2004, 03:29 PM   #11 (permalink)
Nah ..It isnt necessary... I 'l post more later..
Old 04-11-2004, 09:56 AM   #12 (permalink)
Then Y it's happed with me..>!
even my system is uptodate with all updates ...??/
pr@k@sh is offline
Old 04-11-2004, 11:50 PM   #13 (permalink)
i had a similar problem with xp....but its gone after i installed sp2
sagar_mutha is offline
Old 05-11-2004, 12:10 AM   #14 (permalink)
but i have a win 2000 pro and i already SP4 Now what i have to DO..??
pr@k@sh is offline
Old 05-11-2004, 09:09 AM   #15 (permalink)
Reinstall win2k ... If can u afford to format then do clean installation.
It seems most of ur os applications might have gone corrupt to .
suhas_sm is offline
