I have 2 normal cds ,data is compressed in such manner that after extracting it becomes nearly 1.5 GB each but 4Gb is too much and also u r saying these cd's are mini size.
@Akhil Jain
Have u seen or checkd it ?
u r friend may be just fooling!!!
it cannot be read by a cd rom
the guy HAS to be mistaken
a mini cd contains max of 210 mb of data ..
the same size dvd contains a few gb's im not sure how much
but under no case is it a cd ... even with overburning option
remember we arent talkin abt windows 3 in 1 which have common files hence multiple links which give cd capacity as 3.14 gb
we're talkin abt a handycam that writs straight on optical media
hence 4gb on a mini cd is OUT of the question
btw miniDVD ram disks are capable of 2.92 gb of data
miniDVD are 1.47gb in capacity
and mini-DVD is used to describe cds with dvd data on them
No Mercy, No Limits.
miniDVD are 1.47gb in capacity and mini-DVD is used to describe cds with dvd data on them
1. Did you mean Win 3.1? Otherwise pl explain what is Win 3in1.
2. and mini-DVD is used to describe cds with dvd data on them. Is it correct? If so how can it contain 1.47 GB?
Sorry if I am idiotic.
only compression can help that thing afaik no cd can hold data of 4 gb but yes there are compressor which show that the data is 4 gb but is is 600 -689 mb in real may be some copy protection did u copied the cd
