Old 08-03-2006, 04:13 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Du meter ! ! !
i have mtnl triband ...
Du meter shows download/upload speed bt doesnt record time in its database, any solution ???
do u start du meter manually or it automatically detects ur connections & starts ???
ax3 is offline
Old 09-03-2006, 12:15 AM   #2 (permalink)
ur supposed to set du meter to monitor a particular connection
say a lan port or ur dial up connection
no it has no timings in it
also mtnl doesnt count uploads
now to check between what times u used how much u may login to mtnls on site at register.mtnl.net.in
( thats the direct link to check triband usage )
ull need ur username and pwd ofcourse
No Mercy, No Limits.
theraven is offline
- by gforz
