Old 08-03-2006, 02:32 AM   #1 (permalink)
bizzare_blue's Avatar
Default Files playing hide n seek
My friend is facing a strange kind of prob...Wenever he copies some files frm one location to another..they get copied and he can access them frm there. But when the system is restarted, the files are not there bt get back to the original place....he formatted the windows partition n reinstalled the OS bt to no avail...
As he has not formatted whole of the disk I have a doubt if it is a virus in a partition other than the one used for OS installation...plz help me regardin the same..
Bitten by the open-source bug...
bizzare_blue is offline
Old 31-03-2006, 02:26 AM   #2 (permalink)
Still waitin for a reply....
Old 01-04-2006, 03:31 PM   #3 (permalink)
m waitin 4 a reply....
Old 01-04-2006, 08:40 PM   #4 (permalink)
hey..u sure this is no April fool??
What you are saying sounds highly impossible..unless he does system restore..nah even dat does not do anything like this...u usre ur frnd is not playing a prank on you..or u on us??
If u think u r right...u r a bad thinker!
Jatin_T is offline
Old 01-04-2006, 09:02 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yeah, it is totally weird, that cant happen at all...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 01-04-2006, 09:46 PM   #6 (permalink)
I don't think he's playin a prank on me...bt I myself haven't checked out his system as yet...so will c n tell if this is true...
This behaviour is possible wen sum1 uses softz like DEEPFREEZE which may usually b seen in Cyber cafes...
Old 09-04-2006, 03:04 PM   #7 (permalink)
Sry pals....I checked out my frenz PC and he had installed DEEPFREEZE....anyways thnx 4 ur concern.
- by gforz
