Old 07-03-2006, 06:40 PM   #1 (permalink)
Dreaming Future
kin.vachhani's Avatar
Default two os in single drive
here..... its just a question in mind
is it possible to install two operating system in same partition or drive
if yes how to do it.....
World without Computer is like a man without Brain.....
kin.vachhani is offline
Old 07-03-2006, 11:30 PM   #2 (permalink)
Yes, If done properly. But I suggest u not to do this.
U can do this by setting different folder for installation rather than WINDOWS, but windows2 or some thing like that.
Again it can be done for two windows but i don't know about other OS.
Also one windows & one other won't work.
dead-man is offline
Old 08-03-2006, 02:24 PM   #3 (permalink)
yes it is possible with Windows too..
i m running Win98 and Windows 2000 Professional in same drive..and i dont get any problem in it..
Ravi-the Sun
Think Bright,Think Sun
www.ravithesun.c-o.in My Blog
www.sunsoft.c-o.in My Web Home
ravimevcha is offline
Old 08-03-2006, 07:30 PM   #4 (permalink)
::vicky::'s Avatar
hey how is it possible to install that can u guys help me
::vicky:: is offline
Old 08-03-2006, 08:47 PM   #5 (permalink)
nach p's Avatar
You can install 2 OS (windows) on one drive but becomes complicated and never recommended.
While installing 2nd OS just choose path of same drive where first OS is installed.
You cant install Windows and Linux on same drive
nach p is offline
Old 09-03-2006, 10:41 AM   #6 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
but linux formats drive while installing.so wont it format the windows installation?
romeo_8693 is offline
Old 09-03-2006, 11:52 AM   #7 (permalink)
click on mind and think for each MS OS program files is there so u can't seperate any more for two diffren os
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 10-03-2006, 01:00 AM   #8 (permalink)
Dreaming Future
hey guys just give your answers in some what detailed manner of how to do it......i want to install it in single drive so give me detailed information... pls
Old 10-03-2006, 01:32 AM   #9 (permalink)
in my humble opinions, i think that you just have to install them in different folders but install 98 in diff. folder such as win98 etc. because XP does not give option of choosing folder but gives option of choosing only drive. also u cannot install linux and windows on same partition because linux operates using a different filesystem than windows and there can be only one filesystem in a partition. so there u have it. get back if it succeeds
Dumbledore is offline
Old 10-03-2006, 01:32 AM   #10 (permalink)
Old 10-03-2006, 10:12 AM   #11 (permalink)
ramprasad's Avatar
no Dumbledore,
XP does ask for the name of the folder.
I have installed 98 in folder WINDOWS9 and XP in WINDOWSX.
Works perfectly...........
ramprasad is offline
Old 10-03-2006, 10:29 AM   #12 (permalink)
Default May be it will help.
Hi Guys,
Though it is very much possible to install. But it is not really reccomended.
First of all although XP supports both FAT 32 as well as NTFS file systems but still it is ok if we install both XP and 98 using FAT 32.
That wil solve our purpose.
N ways but still since it is a requirement i will definitely try and help.
First i need to know how many paritions u have and what is your storage capacity.
Ok, If i concider your PC to have a standard configuration. Say 40 GB Hard Disk(HD) and 3 partitions.
Let the primary drive be C:
1) First go to Bios and change the booting option to "boot from CD".
2)Once it is done place the 98 CD first and Reboot.
3)The system then asks for the option of boot from CD or boot from HD.
Select "boot from CD".
4)type "fdisk" on DOS prompt. and format C: (There are easy instructions i hope u will manage to do that).
5)then start the 98 installation. Once the 98 is installed, place the XP CD and reboot. similarly Boot from CD and do not format or delete partition.
allow the set up to run and install the OS in the same Drive.
Try it out.
Well it was once required for me to install two XP OS in the same drive and it worked.
So, lets hope it works for different OS also.
Try your luck.
Regards,
Pratik.
pratik_1216 is offline
Old 11-03-2006, 12:00 PM   #13 (permalink)
Dreaming Future
thanks guys but what if i want to do it for sp2 and sp1 in a single drive...
would that be possible like in 98...
and i dont understand how its possible to have linux and windows in a single drive....
linux have its own indexing and windows have its own like ntfs and fat32..
Old 11-03-2006, 03:08 PM   #14 (permalink)
bro u can do it
but consider priority of OS
Old 11-03-2006, 03:09 PM   #15 (permalink)
bro u can do it
Old 12-03-2006, 01:37 AM   #16 (permalink)
Default hi...
Try it out.
Try your luck.
Regards,
Pratik.
the same applies for SP1 or SP2 .
I mean if u wish to inastall it in the same drive...
Regards,
Pratik
Old 22-03-2006, 04:22 PM   #17 (permalink)
The Researcher
i don't know why you want to do this. If u r interestd in running new os, then you may try vmplayer, which is free. google vmplayer and download
Ramakrishnan is offline
Old 22-03-2006, 06:43 PM   #18 (permalink)
Linux can run on FAT32 as well, with certain limitations.
http://www.slackware.com/zipslack/
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
- by gforz
