Please help me . i had a very weird experience with my PC.
Yesterday, my small brother did something with the PC, (the internet was ON). When i came back & switched it ON-- GUESS What !!!! the desktop was totally
BLANK, the wallpaper was there but nothing else. (the desktop was blank with no desktop icons, start menu & taskbar)
i opened up the TASK Manager & under the PROCESS TAB --there was nothing.
Then i opened up the "msconfig" all the settings was fine.
then i restarted the PC in "safe mode" there also, no devices or application loaded up.
then i opened up the TASK MANAGER & under "new task" typed the following to open up the SYSTEM RESTORE APP. "
%systemroot%\system32\restore\rstrui.exe"
which i basically learnt from the additional book Digit gave (Feb 2006)
CAN YOU TELL ME WHAT COULD've BEEN THE PROBLEM.
I'VE ALSO RUN A FULL system scan (both MS Defender & AVG Virus scan.)
My PC config.==HP Pavilion, Windows XP SP2.
