Old 02-11-2004, 10:47 AM   #1 (permalink)
Default Kazaa 2.4.3 banned ???
I have setup of Kazaa lite 2.4.3++
I used to use this program earlier .... then i uninstalled it
now after 2 months when i installed
the setup was perfect but when i start the program it doesnt connect to the net at all
I kept it on for 3 hrs ... while my messengers, forum and other sites were openin ( MY NET WAS CONNECTED!! )
can someone tell me the reason ???
an easier alternative .... tell me a good enough File Sharing Program ...
without Adware / Spyware ... Free and should not take ages to start a download lik eMule
talrejaharish is offline
Old 02-11-2004, 12:39 PM   #2 (permalink)
Already been discussed.
http://www.thinkdigit.com/forum/view...ighlight=kazaa
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 02-11-2004, 07:50 PM   #3 (permalink)
limewire is also good nowadays...and i always thought kazaalite is much better than kazaa
ishaan is offline
Old 04-11-2004, 10:26 AM   #4 (permalink)
check the options in kazaa
deepakuma is offline
Old 04-11-2004, 11:25 AM   #5 (permalink)
Ethan_Hunt's Avatar
Well mate Kazaa has not been banned at all.This seems to be the problem of you ISP's firewall which is probably trying to block Kazaa as most firewall do........Try contacting ur Service provider for more info on when the firewall gets disabled.....Try Using kazaa late at night like round about 11.00 P.M.....
As for another file sharing networks there are a wide ranges available right now search the forum for these or just google it.....or use the current Favourite i.e BitTorrent.....and then try downloading from sites like www.desitorrents.com and www.suprnova.org....good luck mate...
Ethan_Hunt is offline
Old 04-11-2004, 10:43 PM   #6 (permalink)
Try Shareaza
its open source and does not contain any adware or spyware!
it also has p2p radio
www.shareaza.com
happy sharing!!
technovice is offline
Old 05-11-2004, 09:29 PM   #7 (permalink)
check out KazaaGhost on this months digit (november)
ishaan is offline
Old 05-11-2004, 11:26 PM   #8 (permalink)
well kazaa lite has been banned as Sharman Tech makers of KMD say it is illegal. But i use it without any troubles!!
- by gforz
