i have intex usb keyboard.
if i plug in usb port
it works till xp bootscreen comes
then it does not even get power
if i use usb-ps/2 adaptre
sometimes it works
other times all 3 leds on keyboard start blinking
help
so hard to type on on-screen keyboard
I am the Master of Havoc, Wielder of Destruction. I am...
Dheeraj Kumar!
Maybe you should try and plug that keyboard of yours to someone else's system, like the PC of your friend or at school/college/work. Just to see that it isn't erratic at your terminal only.
__________________ One great use of words is to hide our thoughts.
does xp support usb keyboards?
i evern tried enabline usb kb support in bios.
problem persists
as kb works in dos mode, before windows loads,
it must be problem with xp not supporting my keyboard or something...
edit:does anyone have any keyboard driver for winxp, mine is an intex make
Dheeraj Kumar!
