Old 06-03-2006, 07:45 PM   #1 (permalink)
LegendKiller's Avatar
Default IE-7 uninstallation...
I recently formatted and re-installed windows on my pc.after which i copied ny account folder,which i had from my previous installations,so that i don't have problems with my settings for my account...
however,since i had installed ie-7 before transferring my accounts folder from prev. installation,it gives me error while uninstalling that plz uninstall it from the account you had installed it????
since my previous account folder over-wrote all setting of the new account,i dont how to get rid of it!
Winxp sp2,NIS 2006
LegendKiller is offline
Old 07-03-2006, 10:05 AM   #2 (permalink)
GeekyBoy's Avatar
Go to Add or Remove Programs,tick on "Show Updates".The list of available updates will be shown.Select "Internet Explorer 7 Beta 1" and then click on remove.
GeekyBoy is offline
Old 07-03-2006, 04:12 PM   #3 (permalink)
i tried it still same error!
i think when i cpied back by original folder from previous installation...my settings for new ie-7 got messed up!
Old 07-03-2006, 04:13 PM   #4 (permalink)
Old 07-03-2006, 04:15 PM   #5 (permalink)
have u rtried to clean entry from registry ?
try it out it hide the presence of s/w in ur hdd .
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
- by gforz
