I have a cd which contains softwares does not autorun in my system thought the autorun has been enabled. If I click the autorun file manualy, it does not work. other cds work fine. Its the setupfile which must autorun, if it doesn't then can't install the sofware!
It works fine in my friends system. What may be the problem. I tried this both in WinMe and WinXP
Navaneeth
My Phones: Motorola T180, Nokia 2600, SE J300i, SE W810i
I THINK YOU'VE CDWRITER in autorun.inf put this setup information to be autorun and burn with your cd can run as before....
you says that your friend've noproblem but your rom and him rom has different efficient work
Hi, The cd is not damaged. It auto-runs in my friends sys perfectly. But it does not autorun in my house & cosin's house though the cd-roms are in good condition and having autorun enabled!
Navaneeth
