06-03-2006, 09:24 AM
Yahoo Mssgr 7 - Can't login anymore!!
Hi
To try Y!Mssgr 7.5 Beta, I installed it.But it didn't worked as even after clicking SIGN IN, nothing happened!!! So i uninstalled it,restarted comp and again Installed Y!M 7.
But Now i can't login in it. It shows this prob:
ZA don't block it,either. What could be the Problem? Please help me!!!!!!
06-03-2006, 09:36 AM
Microsoft MVP
Again try to Uninstall Yahoo! messenger. Then goto "Program files" folder and delete the folder "Yahoo!" (If exists). Now open "regedit" and nevigate to:
HKEY_CURRENT_USER\Software\yahoo
and
HKEY_LOCAL_MACHINE\SOFTWARE\Yahoo
And delete both "Yahoo" keys!
Now try to reinstall Yahoo! messenger...
06-03-2006, 10:20 AM
It didn't work
Still the same problem
"If it weren't for electricity we'd all be watching television by candlelight."
- George Gobel
06-03-2006, 10:23 AM
Where do I find Regedit ?
06-03-2006, 10:41 AM
go to RUN-->>type regedit
- George Gobel
06-03-2006, 11:16 AM
Microsoft MVP
Open Yahoo! Messenger and then close the login window and select Messenger -> Connection Preferences, here play aroud all 4 options, like No proxies, No netwrok detection and check whether it works or not!
Yeah. Sorry wrong question. Completely lost my head there. I'm facing a problem with Yahoo Messenger too : Whener I click on a rollover button, my messg. closes and I'm logged out. I tried uninstalling yahoo, erasing the registry files for it and reinstalling, but the problem persists. Any suggestions ?
06-03-2006, 11:21 AM
Microsoft MVP
What do u mean by "rollover button" ?
Pls be more clear about ur query!
06-03-2006, 11:24 AM
@Gunner
start a new thread
dont mess up plz
@Vishal
Done tthat too.....................nothing worked
- George Gobel
06-03-2006, 11:33 AM
Microsoft MVP
hv u tried with nother ID to login in Yahoo! ?
May be there is some problem with ur ID!
06-03-2006, 11:39 AM
I have also face the same problem as said SWEET SNEHA but solved by reinstalling.I think it's a bug.since it was in beta stage i have said like it...
06-03-2006, 11:45 AM
yeah...........made another id and tried.........but stil prob is there
@logins
i am now on Y!Mssgr 7
its not beta
any link for an older version of Y!M
maybe it'll help
06-03-2006, 12:01 PM
@logins
its not beta
maybe it'll help
I am using yahoo messenger Messenger 7.5.0.333 Beta .Anyway Here is the link for old Yahoo! Messenger 6.0.0.1922:
http://www.takefiles.com/files/ymsgr6_1922.zip
hope u enjoy.
06-03-2006, 12:34 PM
Microsoft MVP
Okie!
I installed Yahoo! 7.5 BETA version and it didnt give me ne problem! Its working fine for me!
For older versions of Yahoo! U can visit here:
Yahoo! Old Versions
Yahoo! Old Apps
Yahoo! Archive
Hope, It'll help U...
06-03-2006, 12:59 PM
Hey sneha,
First u tell r u using any proxy s/w to run d internet connection? Or whic type of the connection do u have?
Just type Ipconfig on dosprompt, & let me know abt all ip settings.....
this is the problem regarding the IP settings Or any 3rd party prg that r blocking ur yahoo messenger ports....
hav u tried msn messenger also?????
Regards
Himanshu
06-03-2006, 02:42 PM
Old versions causing the same problem........
earlier it was fine
just after installing of 7.5 beta(which didn't worked) all problem started
@Him007
here's wat i got:
06-03-2006, 02:44 PM
Install...UK Version....
06-03-2006, 06:15 PM
Microsoft MVP
Seems that the problem is not in the s/w version but exists in the windows installed!
If u hv ne firewall installed, then try to stop it and then try to login in Yahoo! U can disable firewall's entry from startup and then after restarting the system check yahoo!
06-03-2006, 06:53 PM
#19 (permalink)
No, ZA allows it.........i'm sure
- George Gobel
06-03-2006, 07:24 PM
#20 (permalink)
Microsoft MVP
Sneha! Tell me one thing. R u able to login to Yahoo! within browser? If yes! Then its clear that ur account is working fine!
But if u r not able to login in browser also, then first try to Clear all cookies.
Sometimes the problem also exists with ISP, which net connection r u using?
And also take a look here:
yahoo messeger login problem
06-03-2006, 08:43 PM
#21 (permalink)
Yeah, I can LOGIN with Mozilla
I'm using MTNL Triband
Tried everything but nothing is working
Same problem
And thanks for the link although his prob is diff frm mine and also it requires $$$$$ to view sol
Any more solution...if u can
- George Gobel
06-03-2006, 08:55 PM
#22 (permalink)
Some ip yahoo dosen't recognise it....
06-03-2006, 09:41 PM
#23 (permalink)
earlier i could login.............its just after the installation and uninstallation of 7.5beta prob started
- George Gobel
07-03-2006, 12:58 AM
#24 (permalink)
Coming back to life ..
Try the 7.0.120 installer from here. (Direct link to full installer)..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
07-03-2006, 09:37 AM
#25 (permalink)
hey it_waaznt_me, tried but causing the same problem after installation
- George Gobel
08-03-2006, 11:34 AM
#26 (permalink)
Hey Sneha
I asked r u able to use msn messenger? It seems that prob with IP only....where is ur pc connected means router or switch?
hope ur problem will be troubleshooted....
one thing more gv me full deatils of ipconfig
C:\ipconfig/all>ip.txt
Reagrds
Himanshu
08-03-2006, 11:47 AM
#27 (permalink)
Leave it now
I installed XP again and its working on the NEW XP
- George Gobel
08-03-2006, 11:59 AM
#28 (permalink)
This is GOOD, u hv to take the decision earlier...........
Himanshu
08-03-2006, 02:41 PM
#29 (permalink)
Microsoft MVP
That was the last opinion, I was thinking about to give u
neway, ant bhala to sab bhala...
Good to know that the problem has been solved!
09-03-2006, 03:07 PM
#30 (permalink)
Formatting is Aakhri Raasta...
Hey guys,
I am Pratik I am new to this forum.
I had the same problem but i did not reinstall the XP. I just installed Macromedia Flash player and it worked...
the link..
http://www.macromedia.com/shockwave/...ShockwaveFlash
So, now hope u can chat freely..
Regards,
Pratik.
Search this Thread |
