1.i have a samsung 52-32-52 writer, till a month back it worked fine, now it cannot read or write any cd but responds to windows (right click on dcrive and click eject etc work) also the cd spins inside the drive but it cant read from the drive
the cds are fine, as i checked them with another cd drive which i have...
is my lens the problem? if i need to clean it plz gimme some instructions as ive never done it before...
2.i have winxp running and i have windows millenium setup, now i need to install ME in another drive(empty), but running the setup in xp fails...i have some problems doing it in dos so, is it possible?
