Old 05-03-2006, 05:12 PM   #1 (permalink)
Gunner's Avatar
Default Eject and Load
Just a question. On my friend's PC I saw that in my computer, when you right-click on the CD Drive, it gives an option called "Eject". When the tray is ejected, and we right-click on the CD Drive again, it gives the option "Load" instead of "Eject". But on my PC, when I click on "Eject" the CD tray comes out, but when I right click the icon when the CD Tray is out, I still get only the "Eject" option. Not the "Load" option. Is it possible for me to make this option enabled ?
Incase you're wondering - My friend uses and AMD Athlon 64-bit 2800+ with 512 MB Ram, Windows XP Professional OS. I use a Pentium 4 2.8 Ghz with 768 MB RAM and Windows XP Professional Service Pack 2, latest updates and patches installed.
Gunner is offline
Old 05-03-2006, 05:32 PM   #2 (permalink)
Why not?It's possible through software.....
devarajan is offline
Old 05-03-2006, 05:36 PM   #3 (permalink)
Default Re: Eject and Load
Does anyone knows about that kind of software? I also want that.
alanpaladka is offline
Old 05-03-2006, 05:48 PM   #4 (permalink)
readermaniax's Avatar
~~~Why not?It's possible through software.....~~~
then tell us devarajan..
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 05-03-2006, 05:52 PM   #5 (permalink)
Here it is
 http://www.cd-eject-tool.com/downloads/cd-eject-tool-2.6.exe
Old 05-03-2006, 07:24 PM   #6 (permalink)
Wandering in the zone ...
manas's Avatar
The Load option will also come if you install Virtual Clonedrive.
http://files.elby.ch/download/SetupV...loneDrive5.exe
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
Old 05-03-2006, 07:47 PM   #7 (permalink)
Dude had u chk it by using the software????? It has both load and eject option.With the help of url don't come to a conclusion.
Old 05-03-2006, 08:45 PM   #8 (permalink)
I have implemented the same application in visual basic.
I found it not possible to know whether the tray is open or closed.
If you want the code, just send me ur email id.
amitgg is offline
Old 06-03-2006, 09:33 AM   #9 (permalink)
ramprasad's Avatar
hi amitagg,
send it to rp_ramprasad@yahoo.com
ramprasad is offline
Old 06-03-2006, 09:51 AM   #10 (permalink)
Originally Posted by ramprasad
hi amitagg,
Get ur views after testing it.
Old 06-03-2006, 10:17 AM   #11 (permalink)
Gunner's Avatar
Here's my ID : gunner100@gmail.com
Wouldn't it be simpler if u can send the coding via a PM ?
And the CD eject tools, gives me an external option to eject and load CDs. I was talking about an option when I right click on the CD Drive icon in My Computer.
Gunner is offline
Old 06-03-2006, 06:15 PM   #12 (permalink)
Chek ur ids.
hi amitagg,
Gimme ur id and test urself this nice vb application.
amitgg is offline
Old 07-03-2006, 01:47 AM   #13 (permalink)
aadipa's Avatar
Right-click any drive to close the tray of the optical drive
Right click on CD drive to close drive tray (just like the "Eject" option but the opposite function offered in a graphical way)
First get "cdr.exe" from the link in MSFN's official uA CD guide, or from link in this post.
Then put it into "%WindowsRoot%\System32" folder on your hard disk. e.g. If you have Windows installed to C:\windows, then put it in c:\windows\system32.
Copy following code to a new text file and save it as "cdr.reg"
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Drive\shell\draw]
@="Close CD-&tray"
[HKEY_CLASSES_ROOT\Drive\shell\draw\command]
@="cdr.exe close ALL"
Now right click the file and select "Merge".
There are two shortcomings with the above:
a. It closes all optical-drives one after another
b. The option to "close tray" appears even if you right-click on your HD's partitions.
But then, something's better than nothing.
Also, I used to use Nero DriveSpeed to close CD-ROM's until now, but it has 2 disadvantages:
a. It doesn't work for older drives.
b. It's a third-party utility which comes bundled when you install a commercial app.
Original Source Post edited by me
Download CDR.exe
Here is source code that explains the working CDR.EXE - Open/Close CD Drive(s) Programmatically
aadipa is offline
- by gforz
