Originally Posted by eagle_y2j
33 wats up
2k is some what below normal.Any way these r the reson'sfor slow downloading.BitTorrent works on a credit system. By uploading parts of a file other people, they allow you to download parts of the file from them. This is BitTorrent’s anti-leech measure. However, if you have a problem with your NAT (anything between you and the internet, such as a router or firewall), you will not get credit for what you are uploading. The only downloading that you can do is from people who upload a small amount to you in the hope that you will return the favor. Since their client will not recognize your response if you have a firewall problem, then they will stop uploading to you shortly after. This is what is causing your problem. You may also notice that torrent speeds go very high for 5 minutes, before slowing back down to 0-5kb/s.
so therefore no TWEAK
