Old 01-11-2004, 08:41 PM   #1 (permalink)
Default In 2000 domain clint loging errer..???
Dear friends
I format my server and creat new domanin with new name..!!
now from clint Pc with win 2000 Pro i get this errer..!!
The credentials supplied conflict with an existing set 0f credentials
so what i have to do for remove this errer..!!
Help..>!@!
Have A Nice Day....!!
pr@k@sh is offline
Old 03-11-2004, 10:08 AM   #2 (permalink)
2k does not allow you to make multiple connections to a shared network server from the same workstation if you attempt to use more than one set of credentials. If you attempt to make two or more connections to the same server using two or more sets of credentials, you will receive the error message you see.
A simple resolution to this problem would be to disconnect the previous connection(s) to the server.
This behavior is by design for security purposes.
If you require more info about this error, go to http://support.microsoft.com/kb/106211/EN-US/
Keep The Passion Alive!
Destructo is offline
Old 03-11-2004, 10:32 AM   #3 (permalink)
Thanks Dear..!!
I solve my problem is change my domanin in clint to ad . com
like my domain name is prakash and i just add prakash.com
and my problem is solve..!!!
Thanks
pr@k@sh is offline
- by gforz
