Old 01-11-2004, 07:21 PM   #1 (permalink)
sav_more's Avatar
Default tale of 2 pc's
hey guys!
i have 2 systems p4 1.8 & p4 2.4 running on via p4m266a & intel 845 chipsets respectively.
i need to connect these 2.how much will network cards cost along with other things.(approximate)
also if i store mp3 & divX movie files on one pc.can i play them back "SMOOTHLY" on the other.
********tryin to use ubuntu......n lovin it*********
ASUS A8N VM CSM,AMD 3000+ @ 2GHZ,Seagate Barracuda 120Gb,256*2 ddr @400mhz,samsung syncmaster793mb,geforce7300le,samsung CD-RW,creative 4.1
sav_more is offline
Old 01-11-2004, 09:12 PM   #2 (permalink)
alib_i's Avatar
1. if you aim to connect only 2 pcs then you dont need network cards
instead connect them through serial ports ( evey mother board has one )
the cord you need to connect will be just like any other lan cord .. but with one difference. two wires inside the lan chord need to be swapped with each other.
dont bother yourself with the details .. just go to a vendor and ask him to give a lan cord to connect 2 pcs ( not one to connect a pc to hub )
2. its possible to watch movies, listen to mp3s and play games on two comps very smoothly. you need to share them on one comp and run from other
-Metallica
alib_i is offline
Old 01-11-2004, 11:06 PM   #3 (permalink)
no no the serial link is a very bad idea (a very frustrating one as it is low speed) buy two 100mbps lan cards and a patch cable connect the two to enjoy sharing of data total cost Rs 200 * 2 = 400 for cards and Rs 50 for the patch cable.
**** happens
pradeep_chauhan is offline
Old 02-11-2004, 09:47 AM   #4 (permalink)
sav_more's Avatar
thanks guys.
100 mbps lancard it is.i never thought it would b so cheap.
!!!peace!!!
sav_more is offline
Old 02-11-2004, 03:09 PM   #5 (permalink)
also make sure ur cable is a cross-over cable else you wont be able to connect the 2 machine and communicate with each other.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 02-11-2004, 04:28 PM   #6 (permalink)
ice
Ya, u will need cat-5 cables, according to length and two lan cards
And yes, u will be able to see movies/listen to music smoothly. Ive been doin it for a yr and a half or so.
ice
ice is offline
- by gforz
