Old 03-03-2006, 04:50 PM   #1 (permalink)
Default registry prob.
ever time i execute a .reg file it open in notepad, when i right clicked it and select merge
then it also opened in notepad
what's the prob
i want to merge the registry when i execute it.,and when i select edit by right clicking on the file then only it opens in notepad....
windows xp pro
thadhanihemant is offline
Old 03-03-2006, 06:31 PM   #2 (permalink)
it seems like ur ".reg" file type is registered to open with Notepad.
Go to Folder Option --> File Type and selecte ".reg" file type.
then in Open action of this filetype type regedit.exe "%1"
hope this will solve ur problem..
Ravi-the Sun
Think Bright,Think Sun
www.ravithesun.c-o.in My Blog
www.sunsoft.c-o.in My Web Home
ravimevcha is offline
Old 04-03-2006, 12:41 AM   #3 (permalink)
thanks alot problem solved
moderator plz lock lock the thread................
- by gforz
