Old 03-03-2006, 02:32 PM   #1 (permalink)
Learner
Kniwor's Avatar
Default my removable HDD, which OS...
ok, i tried putting SLAX Kill-Bill on my removable 40Gb hard disk, but for some reason i could not boot from it instead of doing everything fine... It boots from the HDD, but the OS doesnt load....
now i want to have suggesion on what can i install on this hard disk, i will use it as a live OS on any machine, so should basically be like some live CD, what should i install, link to it??
Kniwor is offline
Old 05-03-2006, 12:37 AM   #2 (permalink)
The Incredible's Avatar
i cant understand wat u r trying to say. pls explain a little bit
The Incredible is offline
Old 05-03-2006, 01:02 AM   #3 (permalink)
readermaniax's Avatar
as far as i know SLAX Kill-Bill is a linux ...
link to download it is http://slax.linux-live.org/download.php
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 05-03-2006, 04:04 AM   #4 (permalink)
i too have an usb hdd case with 20 GB seagate hdd
I want to install win XP in it and boot from it on any PC i connect.. how to do that?
ashnik is offline
Old 05-03-2006, 06:05 AM   #5 (permalink)
nil_3's Avatar
The actual question is "How to boot from a removable USB storage device"?
It should be done by changing the MoBo BIOS settings.
nil_3 is offline
Old 05-03-2006, 06:10 AM   #6 (permalink)
Booting from a USB flash drive is simple, if the computer system's BIOS supports it. With the power off, plug in the USB device into the USB port on the computer. Turn the power on. During startup, a Boot Device Menu is usually available by pressing the F8 function key. Simply select the "USB drive" from the Boot Device Menu and the computer should boot from the flash drive. If a Boot Device Menu is not available after the computer system has inventoried the drives available, you may have still be able to boot a flash drive by configuring the boot sequence order in the BIOS setup. After booting, the flash drive should be identified as drive "A" or "B" even though the device is not a floppy disk drive.
devarajan is offline
- by gforz
