02-03-2006, 11:08 PM
O dear digitends i am so sad here ,plz help me to solve this
dear friends my problem is:
wen i connect my computer to internet .....
and check mails and visit didgit site,....
one new window will automaticaly come over oll internet xplorer windows...
by name ....BEST PROMOS.....
and wen i click on any links ...
my computer will disconnect from internet and soon dail an international phonenumber....
sum times it carry sum dirty pictuers..
plz tell me how to avoid this windows..............plz
02-03-2006, 11:35 PM
if windows XP or win 98 the type "Msconfig" in RUN box and in "STARTUP" section , uncheck all unwanted stuff (only keep antivirus and regscan checked).
Also goto safe mode and uninstall any unwanted program from cp. (ok that was simple.. try it .. otherwise we will play with registry also)
02-03-2006, 11:38 PM
It's spyware.Download Ad-Aware and run a full system scan.
02-03-2006, 11:51 PM
Dear friendz ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
dear friends i think u for ur reply ,,,,,,but if u tell me sum othr solutions ...it vill b gud for me
03-03-2006, 12:03 AM
Location: a small room in a big house in a small street in a big city
buddy, there isnt a viable 'some other solution'.
Use some good anti-spyware softwares like 'Spy-Bot' or 'Ad-Aware' (as suggested by dIgItaL_BrAt) to get rid of the problems.
Atleast use the 'System Mechanic 6' provided in the February 2006 CD. (That should solve most of the problem).
(Speaking of 'Some other solution', i have this
Use a anti-pop up software. Its all available at www.download.com
OR
You could use Opera which comes with inbuilt pop-up blocker.
Hooray for games. (unfortunately i cant play any of \'em)
03-03-2006, 12:14 AM
there is no other solution u can use
spybot search and destroy
adware
or use the sys mech 6 or 5
etc
03-03-2006, 12:28 AM
send us your hijackthis list
Originally Posted by readermaniax
Steps to Take Before Posting your Hijack This Log
If you are not using the latest version of Hijack This, Version 1.98.2, please download it from: Do not run Hijack This from a temporary folder. HJT makes backups for items that are fixed. Any backups saved in a temporary folder run the risk of being deleted. Backups are important in case a previous fix needs to be restored. It's best to make a permanent folder: C:\HJT this for example. Any place other than a temporary folder is fine.
If you have your own anti-virus program, please update it and do a complete scan.
Use Trend Micro's Online scanner
http://housecall.trendmicro.com/hous...start_corp.asp
Housecall often finds things that popular AV programs miss.
Select your location and click go. If you have never used Trend Micro's online scanner before, you will have to install their active X component. After that is finished installing, the update engine and pattern file will begin downloading. If you are on a dialup connection, this will take several minutes but it's well worth the wait.
To use Housecall, you need one of the following browsers:
Microsoft Internet Explorer (version 4.0 or above)
Netscape Navigator (version 3.01 or above)
Check 'Auto Clean' and 'My computer' and click 'Scan'.
Download these two programs Install and update both. Reboot into Safe Mode and use one then reboot again into safe mode and run the other.
Here are instructions on how to use both programs: Go to add/Remove programs and check and see if you have any of the following programs. Remove them if present. These programs are known to be packaged with or are adware/spyware/malware:
If the folders for any of the above programs are still present, remove those as well. If you're not sure about a particular folder, ask about it in your post. More programs will be added in the future. Some programs on the list may not be removable via Add/Remove programs. Click on a specific entry for manual removal instructions or programs that will detect and remove these.
If you unsure about other programs on your computer, please search this database:
http://www.spywareguide.com/product_search.php
A partial search query generally works best: 'Bon' or 'Bud' will return Bonzi Buddy, for example. A full list can be viewed at this sight as well as different categories of adware/spyware/malware.
Finally, reboot normally. Run Hijack This, Scan and post the log. Make sure you post the complete log including the HJT version and Windows version information. Include a detailed description of the problems you are experiencing. When posting, use a descriptive topic title:
Hijack This Log - {Place Brief Description of the Problem Here}
(example: HijackThis Log - Windows constantly reboots)
If the particular problem that prompted you to post a log goes away after following the above steps, please post a fresh log anyway. Sometimes a problem will return after a reboot if it was not removed successfully. Once it has been determined your system is clean, additional follow-up steps will be given. It is important to follow any steps given to ensure a good 'fix'.
After posting your log, someone will analyze it as soon as possible and give you further instructions.
Please be patient. The analysis can sometimes take awhile. The time will depend on the amount of spyware/malware which is on your system. Hopefully the above steps will fix most, if not all, of the problems.
this is the source
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
03-03-2006, 12:56 AM
Ok flash,
This is an adware. So, your best alternative is to install and use Ad-Aware.
03-03-2006, 06:46 AM
U have dailer....Try to remove it using Microsoft antispyware...What i feel is better reinstall the os b'coz cleaning like these program will never give a 100% solution.And to avoid these better install the protection software.Prevention is better than cure know???.
03-03-2006, 08:42 PM
Yes I totally agree. These softwares will not give you 100% results. So reinstalling is the best option.
04-03-2006, 11:33 AM
use spysweeper. its the best one.
Kind, intelligent, loving and hot.
This describes everything you are not.
04-03-2006, 01:55 PM
hey spware doctor is also best from www.pctools.com
04-03-2006, 03:38 PM
look,spysweeper and spyware doctor are better than ad-aware,but ad-aware is easy to use and effective,i would also suggest ad-aware..
05-03-2006, 01:11 PM
thank u oll for giving me advice ........ thanx alot.....
Search this Thread |
