Old 02-03-2006, 12:27 AM   #1 (permalink)
bsb
Default Computer powers on but doesn't work.
I have assembled my PC about one and half year back. It is AMD Athlon Based Computer with A7n8X Dlx motherboard, 512 MB Ram, Two dists (One SATA 80 GB one IDE 8 GB), running on XP.
For Past few days, I am facing this problem
On switchin on the computer, it powers on, i.e., indicator lights are on, the fan moves but there is no effect on any of the peripheral, i.e, key board, mouse, monitor...so basically nothing happens.
It appears as if BIOS itself is not loading.
I was facing this problem for last two months but for many days, everything used to work if i kept the PC box switched on for 10-15 minutes and re-switched again. But for last 15 days, nothing happens simply.
Can anybody explain to me ..whats going on and what should I do now.
Regards,
B S Bora
PS: I have already changed the mothrboard battery. No improvement.
bsb is offline
Old 02-03-2006, 12:53 AM   #2 (permalink)
Chk out with cabale's.......
devarajan is offline
Old 02-03-2006, 01:23 AM   #3 (permalink)
Indian by heart
planetcall's Avatar
Maybe SMPS. I had similar problem. My 300W SMPS had problem which I detected after many hassles. I strongly suggest you get it checked.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
Old 02-03-2006, 03:20 AM   #4 (permalink)
check if the monitor is working fine or not..
remove the monitor cable frm the back of the CPU and see if any display comes on ..
remove RAM modules and re-insert them...
if re-seating of RAM doesn't work start by removing devices one-by-one..remove all the PCI devices like mode,LAN card etc...restart and check..
i think i was having the same problem with my first PC...HP Pavilion... but i dont think i did anything for this issue..went away on its own!
PS>>>Do u use UPS ??
grinning_devil is offline
Old 02-03-2006, 02:13 PM   #5 (permalink)
the problem lies either with ur SMPS or ur motherbaord
ur not getting any beeps at startup are u ?
check the smps first else ull need to replace r mobo afaik
No Mercy, No Limits.
theraven is offline
Old 02-03-2006, 05:01 PM   #6 (permalink)
Yes, how many beeps you are getting on start up? Make sure that everything is properly inserted. Also try cleaning the contats of rams by using an eraser (ordinary pencil eraser).
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 02-03-2006, 05:06 PM   #7 (permalink)
cleaning with pencil eraser???
never heard of it...and havnt tried it...
good trick if it works...
Old 03-03-2006, 09:17 PM   #8 (permalink)
Check the battery also, just remove and re insert it
mahender is offline
Old 04-03-2006, 02:00 PM   #9 (permalink)
::vicky::'s Avatar
sir ram is not properly seated or the ram is gone
::vicky:: is offline
Old 04-03-2006, 04:14 PM   #10 (permalink)
bsb
Thanks to everyone who responded,
Problem resolved.
SMPS is OK. Re-inserting Battery and RAM solved the problem.
Thanks again
bsb
bsb is offline
Old 05-03-2006, 12:20 AM   #11 (permalink)
The Incredible's Avatar
i know that the problem is solved but i have a query. the guy said that if he kept his pc on for 10 to 15 min then it works. is similar to a car whose battery is down. after accelerating for a few min, the battery get recharged a little bit. so was it d prob cos if it was then this mns dat his batt is low and he need get a new one.
but if the batt is down for how long his pc keeps on working and why?
and yeh if ram is the prob then can sum1 tell how can it b da prob
although his prob is solved but who was d culprit???
The Incredible is offline
Old 05-03-2006, 09:13 PM   #12 (permalink)
I had a similar problem. I just removed the cpu and cleaned the slot thoroughly. It worked. Maybe after somtime the fan blew away some of the dust and the motherboard started working!!!!!!!!!!!!!!!!!!!!!!!
hsksattish is offline
- by gforz
