Old 01-03-2006, 03:30 PM   #1 (permalink)
Default Internal Server Erro IIS
I'm getting 500-Internal server error while using IIS.
What could be the possible reasons.
amitgg is offline
Old 01-03-2006, 06:56 PM   #2 (permalink)
When users try to access content on a server that is running Internet Information Services (IIS) through HTTP or File Transfer Protocol (FTP), IIS returns a numeric code that indicates the status of the request. This status code is recorded in the IIS log, and it may also be displayed in the Web browser or FTP client. The status code can indicate whether a particular request is successful or unsuccessful and can also reveal the exact reason why a request is unsuccessful.
More info chk in: http://support.microsoft.com/?id=318380
devarajan is offline
Old 02-03-2006, 10:54 PM   #3 (permalink)
For which server side scripting language(asp,php..), you get that error?
The possible reason could be you haven't configred that language correctly in ur server.
alanpaladka is offline
Old 04-03-2006, 02:12 PM   #4 (permalink)
::vicky::'s Avatar
try this open ur command prompt and type
aspnet_regiis.exe /i
if nothing happens then open the command prompt of urvb.net and then write there this thing plz also tell us which software are u using are u using visual studio.net
::vicky:: is offline
Old 06-03-2006, 01:54 PM   #5 (permalink)
C:\Documents and Settings\a>aspnet_regiis.exe /i
'aspnet_regiis.exe' is not recognized as an internal or external command,
operable program or batch file.
amitgg is offline
Old 07-03-2006, 04:30 PM   #6 (permalink)
Okay, I figured it out in the end:
1. Uninstall IIS.
2. run "msdtc.exe -uninstall" in the windows/system32 directory.
3. In regedit delete the key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSDTC
4. run "msdtc.exe -install" in the windows/system32 directory.
5. Install IIS.
amitgg is offline
- by gforz
