Old 01-03-2006, 12:31 PM   #1 (permalink)
Ignorance is BLISS !!
Default DOS Command Disabling
Can certain DOS commands be disabled for a user or a particular group of users on a XP / win2000 OS ?
Remember.....I didn't ask to disable the Command Prompt..
Just disabling some commands is all I need !
rajkumar_personal is offline
Old 01-03-2006, 11:52 PM   #2 (permalink)
well i don't know if it is possible but if in external commands if u del the file related to these commands then the command will not work
note that it is only possible in external commands
as far as i know
the files to external commands r located in
X:\WINDOWS\system32
with the same name as of the command.
to disable it just move it to another location......
after moving if u run these commands then dos will say it not an recognized command that't it............
thadhanihemant is offline
Old 04-03-2006, 10:17 AM   #3 (permalink)
But then.......
I'll have to use the machine as well andthat means that whenever I have to use DOS commands, I'll have to do a copy paste and when I'm done, I'll have to delete the files again !!!
VERY tedious solution !
I am sure that a better one exists.
Old 04-03-2006, 11:42 AM   #4 (permalink)
Could this be what you are looking for? http://democity.drn.digitalriver.com/product.php[id]4203[SiteID]democity - I havent tried it but it seems to fit the bill...
Arun
sakumar79 is offline
Old 04-03-2006, 02:09 PM   #5 (permalink)
Sort of OKAY.......
But it is a software and i don't want to use a software for the purpose...
There has to be a workaround for doing it manually !
Old 04-03-2006, 07:00 PM   #6 (permalink)
i am guewssing its something to do with config.sys..
do you know that there are about 10 undocumented commands in dos?
try googling for them....might help...
I am the Master of Havoc, Wielder of Destruction. I am...
Dheeraj Kumar!
imported_dheeraj_kumar is offline
Old 05-03-2006, 12:10 AM   #7 (permalink)
readermaniax's Avatar
HEy you can try searchin it here http://www.mdgx.com/secrets.htm
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 05-03-2006, 10:44 PM   #8 (permalink)
nope, i know about these already, the ones im talking about start with &. they make dos work like a programming language really, to make loops etc.
put those stuff in a batch file and your proggie is ready. pity they were not documented...
Dheeraj Kumar!
Old 20-03-2006, 10:19 AM   #9 (permalink)
But hey.....
My prob remains unanswered !
How do i disable certain DOS commands !
Old 21-03-2006, 01:07 AM   #10 (permalink)
if you are a programmer, looks like you've gotta do it the hard way-debug cmd.exe and nop the jump instructions for all the commands you want
it wont be easy, but thats a very plausible solution
i believe this can be done only by patching cmd.exe, and so that software mentioned earlier would onl affect one particular version of windows
Dheeraj Kumar!
Old 21-03-2006, 09:23 AM   #11 (permalink)
Dreaming Future
kin.vachhani's Avatar
one can disable it from the registry..i think so.... not yet try
World without Computer is like a man without Brain.....
kin.vachhani is offline
Old 21-03-2006, 02:14 PM   #12 (permalink)
@kin.vachhani
The idea sounds EXTREMELY crazy !
How can even figure that out ???
If it really happens.......I'll be a great FAN (ceiling fan)of yours !
- by gforz
