Old 27-02-2006, 04:21 PM   #1 (permalink)
Ignorance is BLISS !!
Default REGISTRY Stored ??
I just wanted to know ==> where does the windows registry store its registry contents ??
I checked the size of regedit.exe and it was some odd 200+ KB.
I guess it is so because it is just an interface app.
Where does it actually store the information ?
I exported my registry and it came up to be a whopping 70+ MB
And one more query !!
How can I access the HKCU key of any other user account from the administrator account !
I know I can do it by logging into the users account and see but I Just wanted to know how do i do it without that way !
rajkumar_personal is offline
Old 27-02-2006, 04:36 PM   #2 (permalink)
The physical files that make up the registry are stored differently depending on your version of Windows; under Windows 95, 98 & ME it is contained in two hidden files in your Windows directory, called USER.DAT and SYSTEM.DAT, while under Windows NT/2000 the files are contained separately in the %SystemRoot%\System32\Config directory. You can not edit these files directly, you must use a tool usually known as a "Registry Editor" to make any changes ......
devarajan is offline
Old 27-02-2006, 04:40 PM   #3 (permalink)
"Technologic"
Apollo's Avatar
Default Re: REGISTRY Stored ??
http://www.mcse.ms/archive71-2004-10-1189972.html
Hopefully, it will prove handy!
One great use of words is to hide our thoughts.
Apollo is offline
Old 27-02-2006, 04:48 PM   #4 (permalink)
::vicky::'s Avatar
yes dev is right user.dat and system.dat in windows 98 me and in xp/2000 it is the %SystemRoot%\System32\Config
::vicky:: is offline
- by gforz
