If you dont need system restore then just disable it. It ll definitly improve the overall performance of the system. as said early use msconfig and remove all program that do not need. (for eg: yahoo messenger, msn messenger, Winamp quick player, etc etc). YOu dont need them at start up. If you want them you can later run the application.
