Old 31-10-2004, 03:14 PM   #1 (permalink)
Mobile Freak
reddick's Avatar
Default System ShutDown Automatically!
Hi Dude,
My PC Gets shut-down of it's self.This problem presists after loading WINDOWS and before the Windows Sound.
The specifications r :-
AMD Athlon 2000+
ASUS motherboard
256 MB RAM
40 GB HDD (5400)
Win98SE
Linked with Net via External Modem
I even FORMAT my HDD but d problem is still their.Actually,after it is SHUT-DOWN , d power light blinks and stopped whn i OFF my UPS..!
Why is this happening AGAIN & AGAIN...Tell me wht 2 do...THX 4 ur suggestions...
8) Reddick 8)
reddick is online now
Old 31-10-2004, 03:44 PM   #2 (permalink)
please give more details
firstly - is the system working fine in 98?
does the logon screnn comes up or not?
if your is single user doest the windows blue screnn comes up?
also try going into safe mode and mention the programs being loaded in startup using msconfig.exe
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 31-10-2004, 03:48 PM   #3 (permalink)
vysakh's Avatar
very funny
vysakh is offline
Old 31-10-2004, 04:00 PM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
Did someone play a prank with your windows registry... its possible to make such a setting... check out your autorun settings with msconfig or else, post your HijackThis log file (as Batty says )
http://web.gnuer.org
GNUrag is offline
Old 31-10-2004, 04:06 PM   #5 (permalink)
i am assuming a7v8x-mx
- in bios check option called ac power loss restart , change to off
- check temp in bios
- increase shutdown temp to 95
- clear cmos if above steps dont work
- if ur able to go to safe mode , probably problem with drivers .
- check asus site for latest bios and the bugs fixed by it
klinux is offline
- by gforz
