Old 26-02-2006, 06:31 PM   #1 (permalink)
Default "improper shutdown" msg on proper shutdown
Hi,
my windows xp keeps doing that crappy chkdisk even when i shutdown properly.
how can i turn this off? i dont remember activaying anyhtig like that... hhow did it come on automatically?
Vishnu
mvishnu is offline
Old 26-02-2006, 06:37 PM   #2 (permalink)
Run Regedit and navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager. Now double-click on BootExecute. When the dialog box opens, change the value to autocheck autochk * and click on OK. Close Regedit. When you restart, chkdisk will not run.
If you want to make a .reg file to import it instead, just copy the info below and paste it into a text file and rename the extension from .txt to .reg, then double click the file to import into the registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager]
"BootExecute"=hex(7):61,00,75,00,74,00,6f,00,63,00 ,68,00,65,00,63,00,6b,00,20,\
00,61,00,75,00,74,00,6f,00,63,00,68,00,6b,00,20,00 ,2a,00,00,00,00,00
devarajan is offline
Old 26-02-2006, 06:50 PM   #3 (permalink)
thank u very much, devarajan....
i prefer tthe regedit method... it feels more HiFi for me
A man needs a certain amount of madness to cut the rope and set him free...
mvishnu is offline
- by gforz
