Old 31-10-2004, 08:30 AM   #1 (permalink)
Default Having problems with my Athlon XP.. Help needed urgently
I have an athlon xp 2000+, with 256 mb of ram and a geforce fx 5200. My problem is that it freezes randomly. I mean it just locks up, the display freezes at the frame where it was, even the mouse pointer doesn't work i.e, it freezes completely. I have all the latest software for my hardware and have adequate cooling installed for my processor and my video card. I am running windows XP sp2 and have even reinstalled everything. have tried searching the internet to no avail.
can somebody please help? i have lost important data because of this
thank you in advance
mohanbhinder is offline
Old 31-10-2004, 10:01 AM   #2 (permalink)
give more details on error and config of system , including power supply and wattage . till then try these
- whats ur m/b . does it have onboard graphics . if so remove the graphics card and see if u get the error
- try clearing cmos
- in bios check these and reduce the settings , agp apeture , agp mode ( like 8x , 4x ) , assign irq to vga (enabled) .
- run the dxdiag and see if all the options in display are running and run the tests .
- check event viewer in admintool to see if there are any errors , if so post it here
klinux is offline
Old 01-11-2004, 08:29 PM   #3 (permalink)
King of my own Castle
freshseasons's Avatar
Typical IRQ problem...( Conflict ) ..Or Bad Ram....Try chaning a ram module.....or going to Bios a selecting Latency timer to 3 instead of 2 for more compactiibility.
Try resetting the pagefile....
freshseasons is offline
Old 01-11-2004, 10:55 PM   #4 (permalink)
Very little details , well if you look at my pc config , i have the same gaphics card too, well first of all there could be a number of reasons , once i had the problem due to excessive overclocking , once i had this problem due to a faulty network adaptor , so do check in the device manager and check the configrations ,try enabling and disabling some devices and try .
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 01-11-2004, 11:57 PM   #5 (permalink)
Well over clocking may be a problem, but I think u running under low virtual memory. It can also happen due to fragments, try defrag. Then Look for the Clocking, after this check your graphics memory as well as RAM, and finally mother board setting. If still the problem survives then contact your Hardware vendor. You are in serious problem.
Ooops look for the virus also as well as for the texla
Roy (U can belive or cam\'t but this is true, this is Royal)
Dipteshghoshroy is offline
- by soumya
- by tv6952
