Old 25-02-2006, 01:38 PM   #1 (permalink)
nach p's Avatar
Default Choosing Allocation Unit Size
While formatting we have to choose Allocation Unit Size which ranges from 512 bytes to 64 kb.I have an Ntfs file system.
Selecting any size have same effect or diffrent effect on Hdd size ?
For normal usage which size should be choosen?
nach p is offline
Old 25-02-2006, 01:57 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: Choosing Allocation Unit Size
choose default Allocation size unless u have special needs
gary4gar is offline
Old 25-02-2006, 03:03 PM   #3 (permalink)
bit
bit's Avatar
format with default allocation size i.e 4K for both fat32 and ntfs, if you choose different cluster size some defragger might not work.
bit is offline
Old 25-02-2006, 11:35 PM   #4 (permalink)
what'z the advantage or disadvantage in changing the allocation size from default to other value????????????????
thadhanihemant is offline
