Old 23-02-2006, 10:05 PM   #1 (permalink)
C.A.
abhishek66's Avatar
Default HELP!! URGENT
Yesterday, I noticed my computer was running very slow and today there was a burning smell coming from my CPU. I opened the cabinet and checked the fan which is working properly. Please advise what could the problem be?
abhishek66 is offline
Old 23-02-2006, 10:13 PM   #2 (permalink)
Try by keeping out .if it's dumped in a cabin?????
evildeadregeneration is offline
Old 23-02-2006, 10:24 PM   #3 (permalink)
bang bang!
Chirag's Avatar
I also had similar prob. I opened my caby cleaned the dust and now I keep my caby open. No probs now.
Chirag is offline
Old 23-02-2006, 10:25 PM   #4 (permalink)
nach p's Avatar
Check SMPS ,burning smell can be coming from smps.
Please post u r PC Config. in details.
It can help to solve the problem.
nach p is offline
Old 23-02-2006, 10:45 PM   #5 (permalink)
Get me detail's of sys's config and were u have been keeping it?????
Old 23-02-2006, 11:51 PM   #6 (permalink)
its got to be SMPS,
i too have experineced this arnd 2 years back...
change the SMPS....after cleaning out all the accumulated dust..keep the cabinet open..place it in an open area....and if possible try to pin point the exact burning place....
nd ofcourse as others suggested...full pc config needed!
grinning_devil is offline
Old 24-02-2006, 12:19 AM   #7 (permalink)
::vicky::'s Avatar
u open both the side of ur cabinet and if u work try to keep the fan or a/c on .
one thing more if u recently added any hardware remove it
get ur computer serviced by a engineer,if u can do it is good
::vicky:: is offline
Old 24-02-2006, 12:35 AM   #8 (permalink)
C.A.
abhishek66's Avatar
i have p4 3ghz HT with intel 865gbf motherboard.
512ddr ram, segate and samsung hardisk, mercury cabinet.
the computer takes a lot of time to startup now.
i keep the pc in my bedroom but the room is not very airy and also i don't have ac in the room.
now how should i clean the smps.... should i blow the dust out with the help of a vaccum cleaner???
Old 24-02-2006, 03:34 AM   #9 (permalink)
::vicky::'s Avatar
yes if u have that blower give it a try
Old 24-02-2006, 08:05 AM   #10 (permalink)
do NOT open SMPS....simply use blower or vaccum cleaer on not just the SMPS but on the whole computer!
