Old 30-10-2004, 08:17 PM   #1 (permalink)
We Both Have a Mouse!!!
nishantv2003's Avatar
Default Got any nice Tweaks, post them here
CDFS Tweaks
Whats the one thing we hate most when copying something from CD, for me at least, is the speed in which the data is copied.
After many months of research, I have found what I consider the best CDFS settings to have, and my DVD drive never copied so good
Here is the changes that must be made
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\FileSystem\CDFS
Look for that registry key, if not there, we must create a new key, then add the following values
CacheSize, this must be added as a binary value, then type in this value: ff ff 00 00
Prefetch, this key must be added as a DWORD value, then type in this value: 4000 hex
PrefetchTail, this key must be added as a DWORD value, then type in this value: 4000 hex
After that tweaking, try copying something across from CD, and you will notice it does produce a speed boost, but it becomes apparent after a while of using this tweak, you may or may not see it at first.
Let the ripping begin
sorce:flex
nishantv2003 is offline
Old 30-10-2004, 10:30 PM   #2 (permalink)
Remove shortcut arrow from desktop icons
Start regedit.
Navigate to HKEY_CLASSES_ROOT\lnkfile
Delete the IsShortcut registry value.
You may need to restart Windows XP.
C2D E6750@3.6GHz - XFX 650i Ultra - XFX 8600GT - 2x1 2GB 800MHz JetRam - CoolerMaster eXtreme Power Duo 600W - 750GB HDD - LiteOn LightScribe DVD RW -
HP W1907 19" Wide...
and Altec Lansing ATP3...
Old 30-10-2004, 10:33 PM   #3 (permalink)
This is an unique technique for XP, which could improve the performance significantly by tweaking the prefetcher. Recommended hardware: PIII 800 or higher, 512M RAM or more.
1. run "regedit";
2. goto [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager\Memory Management\PrefetchParameters\EnablePrefetcher];
3. Set the value to either 0-Disable, 1-App launch prefetch, 2-Boot Prefetch, 3-Both ("3" is recommended).
4. reboot.
It will decrease the boot time but double and increase the performance of your XP. Try it!
Old 30-10-2004, 10:34 PM   #4 (permalink)
No more low disk space messages
go into registry with REGEDIT.EXE, go to
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer\
and (if not already there) add DWORD (without quotes) "NoLowDiskSpaceChecks" and change the value to 1. Restart.
Old 30-10-2004, 10:36 PM   #5 (permalink)
Get rid of the Recycle Bin
- Are you fed up with the Recycle Bin?
- You never restore deleted items, just empty the Recycle Bin at times?
If yes, then first click the Recycle Bin icon with the 2nd mouse button, and at the "Global" tab, do the following:
Then, copy and paste this to Notepad, and save as "Recycler_Off.reg" and merge it to the registry.
QUOTE
REGEDIT4
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\HideDesktopIcons]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\HideDesktopIcons\ClassicStartMe nu]
"{645FF040-5081-101B-9F08-00AA002F954E}"=dword:00000001
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\HideDesktopIcons\NewStartPanel]
Click once on the desktop, refresh (F5) and there is no more Recycle Bin!
To get the Recycle Bin back, merge this to registry (copy/paste to Notepad, save as "Recycler_on.reg"):
QUOTE
REGEDIT4
"{645FF040-5081-101B-9F08-00AA002F954E}"=dword:00000000
Old 30-10-2004, 11:14 PM   #6 (permalink)
Please mention the source, if i'm right, most has been taken from www.tweakxp.com
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 31-10-2004, 12:06 AM   #7 (permalink)
allready told they r from "flex".lol
Old 31-10-2004, 09:28 AM   #8 (permalink)
Sorry mate, didn't see that
ujjwal is offline
- by soumya
- by tv6952
