Old 23-02-2006, 12:03 AM   #1 (permalink)
Default Unable to remove Smitfraud-C by spybot ,,,
hey guys,,,
it was nice surprise for me after checking log of spybot ,,why becoz,,
Smitfraud-C.: Temporary file (File, nothing done)
C:\Documents and Settings\Administrator\Local Settings\Temp\_iu14D2N.tmp
and after searching on googe its trojen,,,,,,
then how to remove this one,,,,,,,
regards
manoj
mkmkmk is offline
Old 23-02-2006, 01:25 AM   #2 (permalink)
swatkat's Avatar
Hi,
Is your Desktop wallpaper is "normal" or is it chaned to something else? Download CCleaner and install it.
Next, in Safe Mode, run CCleaner, click "Options" button and here go to "Advanced" tab and uncheck the option "Only delete files in Windows Temp folder older than 48 hours". Click OK to exit from the Options. Finally click "Run Cleaner" and click "OK" to continue cleaning.
After this, reboot the PC and check whether SpyBot SnD detects Smitfraud or not.
http://swatrant.blogspot.com/
swatkat is offline
Old 23-02-2006, 11:26 AM   #3 (permalink)
Thanks swatcat,,,,,,,
as per u r instructions i did all and now spy bot showing congrats no infected detected,
ya i was facing BSODs since some day
and lot of time desktop changed in to totoally white backgroud,,
thanks very much dude,,
regards
manoj
mkmkmk is offline
Old 23-02-2006, 11:31 AM   #4 (permalink)
one more question swatcat,,,,,,
is it ok if i will keep cc cleaner advanced option that u mentioned UNchecked for always,,,,,,,
thanking u
manoj
mkmkmk is offline
Old 24-02-2006, 01:18 AM   #5 (permalink)
swatkat's Avatar
Yes, no problem with that option in CCleaner And, by the way, is your wallpaper back to normal?
swatkat is offline
Old 26-02-2006, 01:05 AM   #6 (permalink)
ya its back now thanks swatcat,,,,,,,,,,
regards
manoj
mkmkmk is offline
