Old 22-02-2006, 09:58 PM   #1 (permalink)
Default how can i make DOS system calls in Java ?
hello der ,
I need to know how i can make DOS system calls like "dir" or even "cls" , "ipconfig" from inside a Java program........................ i need to know the packages i need to import ................... ne Java xperts out der ..... pls help ......................
.... not so xperienced Java programmer
ch405 is offline
Old 22-02-2006, 10:29 PM   #2 (permalink)
siriusb's Avatar
Use the process class. This website has the full code:
http://www.javaworld.com/javaworld/j...229-traps.html
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 23-02-2006, 10:58 AM   #3 (permalink)
parthbarot's Avatar
i m java dev.
we can make all comands in java but using java code..
here it is using the runtime...directly...no need for more code...
grt link man...grt stuff there.
thanks.
www.techlads.com
Paarth.
parthbarot is offline
