Old 22-02-2006, 02:46 PM   #1 (permalink)
Default ie7
hai
i use windows 2000. i ll download internet explorer 7. and i will try to install then i got following message.
" This package does not support your System Architecture(34/64bits)."
what it is that.
pls any one help how to install in my system.
bye.,
saravana.
saro_gn is offline
Old 22-02-2006, 02:53 PM   #2 (permalink)
18 Till I Die............
AS far as I know ie7 isn't supported on windows 2000. Its can only be used with XP and later versions of windows. If it isn't supported you cannot do anything to install it.
mehulved is offline
Old 22-02-2006, 06:12 PM   #3 (permalink)
IE7 Beta 2 Preview is supposed to be supported on Windows 2000; Windows 95; Windows 98; Windows ME; Windows XP systems... as per http://www.microsoft.com/downloads/d...DisplayLang=en website... But there are blogs indicating IE7 wont be available for Win2k... as available at http://blogs.msdn.com/ie/archive/2005/05/27/422721.aspx
Arun
sakumar79 is offline
