Old 22-02-2006, 12:17 AM   #1 (permalink)
Default How to get Proxy Support for a Program?
Hi,
I have a program here which has no support for proxy.
I know the address and the port it uses,but since there is no Proxy support for the program I am unable to use it.
Is there any program with which I can direct the progrom to use proxy?
or get the program to direct its request to proxy?
:roll:
netcracker is offline
Old 22-02-2006, 03:42 PM   #2 (permalink)
siriusb's Avatar
AFAIK, the program itself must support proxies for a proxy to work. You can try wingate server. It may have such functionality.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 22-02-2006, 07:52 PM   #3 (permalink)
I know the site that the program tries to acess, the only thing is that because of the proxy,it is unable to
connect.
I just need to know if i can have a program in betwean the progrm and proxy?????
Old 23-02-2006, 12:58 PM   #4 (permalink)
alib_i's Avatar
There is a way out !
It's not pretty
# Get Sockcap
# Get HTTP-Tunnel ( or YourFreedom or Desproxy or other similar tunneling software )
#In Sockcap .. Add an entry of your software.
Start HTTP-Tunnel and then start your application from inside Sockcap (Run button)
It usually works. but the connection becomes hell lot slow.
For better details .. go to this page : [Tutorial] Get P2P Working behind a Firewall
The "Get Bittorrent Working behind a Firewall" section is what you need
It's possible to make any software work using this method.
(I told you .. it's not pretty )
alibi
-Metallica
alib_i is offline
Old 05-03-2006, 11:48 PM   #5 (permalink)
Thx alib_i
i got it I just had to use sockcap and run the program....
also are there any other programs other then this three that tunnels through proxy(that are free ofcourse
