21-02-2006, 04:54 PM
Problem in computer
Hi
I have a p4 2.8 GHz , 512 RAM , 915 GAG comp with 6200 TC .
After Windows is loaded , the computer waits at the welcome screen for around 40 seconds before the desktop appers.
A toolbar name "AZE SEARCH " is appering in all the folder and explorer windows i open . It contains links to various travel sites , finance , porn etc so i think it is a sort of a spyware . I remove it from the view option but it still appers and my homepage is always changed to a diff site . I scanned my system with spyware doctor and stinger but they did not detect anything . How do i remove it .
\" I Do not like to repeat success , i like to move on to other things \"
21-02-2006, 04:57 PM
try to clean ur registry
it may help u
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
21-02-2006, 05:38 PM
Indian by heart
I suggest one stop solution. Go for Lavasoft AdAware SE. It will take care of all such malwares.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
21-02-2006, 06:35 PM
yes it is is the spware and also check ur add remove programs to see that any aze search is there to remove
but the main reason is adware quick heal is best it is on digit cd/dvd
21-02-2006, 08:09 PM
9437077259
For your first doubt, do you mean that your computer waits for 40 Sec before starting to load your OS, like what happens when you have dual OS...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
21-02-2006, 10:42 PM
No i mean it waits at the welcome screen after loading windows XP when you click on your username , the opening music is played immediately but it takes around 40 seconds to view the desktop.
22-02-2006, 01:15 PM
9437077259
Type the command "msconfig" in run and go to the startup tab and check if there is any software that shouldn't be there. This may happen of some software that is being loaded while startup. If you remove all softwares from Startup in msconfig that you actually dont need, you are sure to get a speedy start up.
Win 7 Ultimate
22-02-2006, 02:51 PM
a defragmentation might also help...also dude try to install a good anti-spyware like Spybot S&D. Anway please come back and post here even if your problem is unsolved by the above mentioned solutions.
http://njaan.blogspot.com/ - A Malayalam Blog
22-02-2006, 06:21 PM
hi i removed all the items from startup but still the problem is there .
22-02-2006, 09:47 PM
9437077259
Then try some good spyware like Spybots or Spysweeper...
Win 7 Ultimate
23-02-2006, 01:31 AM
Hi,
Download HijackThis and unzip it to dedicated folder ( like C:\HJT\hijackthis.exe).
Then run it and click the button Do a System scan and save log file. HijackThis will perform a scan and opens up the log file.
Copy the entire contents of the file and post it here.
http://swatrant.blogspot.com/
Search this Thread |
