Old 30-10-2004, 11:12 AM   #1 (permalink)
nipun_the_gr8
Posts: n/a
Default How can i change.........
Plz can any1 tell me how can i change the name of the folder(s) that r present in "Documents & Settings" folder...............
There is no prblm with the username. It's fine bt i wanna change the names of some folders that r present in documents and settings folder.........
Old 30-10-2004, 11:29 AM   #2 (permalink)
rajat22's Avatar
Rigt click & rename.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 30-10-2004, 11:40 AM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Start > Run > Control Useraccounts2 (press enter)
Or
Right click on My Computer , Select Properties Click on Advanced ..
Under the User Profiles frame, Click Settings ..
Hightlight the user that you want to edit / delete whatever ..
DO NOT DELETE YOURSELF or ADMIN ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 01-11-2004, 05:20 PM   #4 (permalink)
nipun_the_gr8
Posts: n/a
bt i can't change the folder name..........
Old 01-11-2004, 09:25 PM   #5 (permalink)
alib_i's Avatar
my suggestion .... dont change it
its like renaming "program files" ... gonna f*** your system
document an..... has many imp files like your cache and most of software data
-Metallica
alib_i is offline
Old 02-11-2004, 03:09 PM   #6 (permalink)
probably you are not logged in as administrator
Prakhar Agrawal
http://www.consumersofindia.com/inc/...ers/468_60.gif
I am a small man with big dreams.
prakhar_agrawal is offline
