Old 20-02-2006, 12:29 AM   #1 (permalink)
Default Page File size MATTERS ????
hi friendz,
i wonder since many of u guys hav Ram of 1 GB .. and then i m not been able to read any convincing article for Virtual Memory Size for this amount of RAM... i mean to say do you guys have any idea of about what shud b the Size of Virtual Memory in case we have 1 GB RAM ...
as i think with 1 GB RAM if we go by rules then 1.5 GB of Swap memory wud b only Wastefull !!!!!! ..... isn't it !!!
and WHAT is the reason for Swap file for each Partirtion .. wil it not DECREASE the Systen Performance AFTERALL we are splitting the swap file and the splitting is not recommended for optimal performance !!!!
hope u all will answer this querry !!!!
varunchaddha is offline
Old 20-02-2006, 02:49 PM   #2 (permalink)
bit
bit's Avatar
If you have 1 GB Ram disable pagefile. I have 512 MB of ram and I have disabled pagefile. Even when I had 256MB and 384MB. I used to disable pagefile.
Some people claim that few games need pagefile(atleast a very small sized). but I have never faced any problem with pagefile disabled.
I hate paging
bit is offline
Old 20-02-2006, 03:20 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
u have a ram bigger than my page file!!!!!!
pls disable the page file i don't think u will need it for at least running normal applications.
gary4gar is offline
Old 20-02-2006, 03:31 PM   #4 (permalink)
Learner
Kniwor's Avatar
I have 1 Gb of RAM.... a better IDEA is to not disable pagefile but make windows not use it... this way windows will be faster....
but if u play games day n night, it is advisable not to do anyhting to pagefile, bacause 1Gb ram is not too much, if u play BF2 etc u will know that... so in that case if u disable pagfile the system will have to manage with the ram thereby decreasing performance at times, i agree that often 1Gb is not needed at all, but often is not always...
The average depth of ganges is 4ft, this does not mean u can pass the ganges walking... hope u get my point...
Kniwor is offline
Old 20-02-2006, 10:25 PM   #5 (permalink)
hi friendz
i used to play Cricket 2005 .. and sometimes NFSU2 ....
and sometimes i use to do some video editing using .. Adobe Premier, Studio9, Ulead etc ..
And i do LOTS n Lots of DivX Encoding ....
so what pagefile siz wud u recommend me .....
Old 21-02-2006, 01:01 AM   #6 (permalink)
help me too
my sys config
p4 1.7ghz
768 RD Ram
intel d850 mv motherboad
Radeon 9200se 128 MB
how much pagefile should i set
i mostly play games such as gta san andreas, call of duty , medal of honor pacific assault , commandos3,age of empire , nfs underground 2
current size is initial-512mb and max-768 mb,and some tv viewing.with my pinnacle pctv stereo.
is this size is suffice to fulfil my requirement?
thadhanihemant is offline
Old 21-02-2006, 01:28 PM   #7 (permalink)
Learner
Kniwor's Avatar
a pagefile larger than 1 gb will almost never be used... so make it 1 gb
Kniwor is offline
Old 21-02-2006, 03:20 PM   #8 (permalink)
bit
bit's Avatar
All I would say is, If you have Windows 2000 / XP / 2003 / Vista and more than 256 MB of RAM disable pagefile and see whether you face any problems, if no problem arises, be happy with pagefile disabled.
bit is offline
Old 21-02-2006, 10:26 PM   #9 (permalink)
friendz .. i tried DISABLING PageFile ..
but in task manager there is a Column Virtual Memory Size .. and i still hav Value in that Column .. WHY ???? i wonder ..
was WINDOWS managing a Swap file without my concern or authority ...
Old 21-02-2006, 10:34 PM   #10 (permalink)
Please tell us how to!
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 21-02-2006, 10:42 PM   #11 (permalink)
Learner
Kniwor's Avatar
V.Prem Kumar
There's actually nothing to it...
when slipstream windows in nLite it gives u an option of doing so.... enable it...
but this is not suggested for ram less than 512Mb... and I'd not suggest it for less than 1Gb
as i've already said... disabling the pagefile only decreases performance...
Kniwor is offline
Old 21-02-2006, 11:11 PM   #12 (permalink)
[/quote]
as i've already said... disabling the pagefile only decreases performance...[/quote]
Will you pl be more specific. I don't know what is slipstream and nLite.
And I do have 1 GB and do not game.
V.Prem Kumar
V.Prem Kumar
janitha is offline
Old 22-02-2006, 12:10 AM   #13 (permalink)
It will always be good to have a page file......around 500-800mb in a different partition other then windows.
Anycase how much memory are u losing its not that much!!
netcracker is offline
Old 22-02-2006, 12:39 AM   #14 (permalink)
Some apps are designed to use the page file even though the system may have >2 gigs of RAM. This is very true for MS Flight Simulator and has been a known fact (officially recognised by MS). There are many more apps, I'm sure.
Maybe future versions of Windows (and apps that run on it) will not need page files.
Microsoft recommends that you do not disable the page file - http://www.petri.co.il/pagefile_optimization.htm
BTW, I have 1GB RAM and 1500MB fixed page file on a fast second hard drive.
-Keith
Keith Sebastian is offline
Old 22-02-2006, 02:56 PM   #15 (permalink)
bit
bit's Avatar
Same thing happen with me too, but don't worry it is not using hard disk.
bit is offline
