Old 19-02-2006, 09:25 PM   #1 (permalink)
sachin_kothari's Avatar
Default Website
I am developing a website. In the registration page, when the user fills in all the details and clicks the submit button, i want all the content of the fields to be sent to his email-id which he will specify in the form. How do i do it. I am using VBScript for it. I need solutions in VBScript to do it. Thanks in advance.
sachin_kothari is online now
Old 19-02-2006, 11:53 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Put some more light on the question. what is the webserver used ? Its been long since i touched VBScripts. im not sure that VBscripts alone can send email.
Charan is offline
Old 20-02-2006, 08:39 AM   #3 (permalink)
I am using MySQL as webserver. But how does that matters. I just need to send email via VBScript.
Old 20-02-2006, 11:35 AM   #4 (permalink)
Default Re: Website
Not possible using VBscript alone. I think you should use either asp or asp.net to do that. By the way, MySQL is not a webserver. It's a database server. I think you are using either Apache or IIS.
alanpaladka is offline
Old 21-02-2006, 01:48 PM   #5 (permalink)
r u knowing mailto command u can directly do from client's pc
and if u r using asp.net then it have inbuilt rich class of smtp
use smtp.send(sender,receiver,subjact,header,data,prio rity,attachment)
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
