Old 30-10-2004, 12:35 AM   #1 (permalink)
yogi7272's Avatar
Default sound blaster live 24 bit
i have got sound blaster live 24 bit sound card . it's a new version of sound blaster live with 7.1 channel support. does anyone know anything about it ? please share your views on the product. i got it for 2600 rs.
yogi7272 is offline
Old 30-10-2004, 11:11 AM   #2 (permalink)
pedal to metal
suave_guy's Avatar
new version of sound blaster live with 7.1 channel support????
Did ur dealer told u that while u were buying it????
u got it for Rs.2600 ????
plz specify the exact model name of ur product..
your "attitude" is your best friend...
suave_guy is offline
Old 30-10-2004, 03:07 PM   #3 (permalink)
suave it exists ..
didnt know that either
the model is called live 24 bit
and heres more info on it
http://www.soundblaster.com/products/live24bit/
No Mercy, No Limits.
theraven is offline
Old 30-10-2004, 09:18 PM   #4 (permalink)
yogi7272's Avatar
Default reply to a query
ya its called sound blaster live 24 bit. it has support for up to 7.1 channel speakers. i have got this one from lamington road some ten days ago. do check it and please let me know what do you feel about the product.
yogi7272 is offline
Old 30-10-2004, 09:52 PM   #5 (permalink)
It's a very simple card. All it gives you is 7.1 support and 24 bit sound. It's smaller in size than the Sb live 5.1!! That's why it costs only 2.6k. But a very good choice for 7.1 users who need a cheap solution and 24 bit sound + EAX advanced HD.
Antec Cabinet, P4 2.8 ghz (HT), Sony Dvd Rom, XFX 5600 U, MSi 875 Neo2, 80 GB Seagate Barracuda 7200 RPM, Creative SB live 5.1, Creative Inspire 4.1 4400, Corsair 512 MB DDR
Delpiero is offline
Old 16-11-2004, 01:30 PM   #6 (permalink)
i also fell for this card while visiting the Audio video show last week ... bought this one abd a creative 5200 5.1 speaker set to compliment it .. i guess it will be anyday better than creative vibra 128 i'm having right now
http://www.danasoft.com/sig/amitcool2001.jpg
U can run but U can\'t hide!!!!
the_fragger is offline
