Old 18-02-2006, 12:04 AM   #1 (permalink)
tweety_bird_bunny's Avatar
Default only a part of readprocess memory or writeprocess memory
only a part of readprocess memory or writeprocess memory request was completed....i get this error whenever i try to run some of my executable files such as easy cd creator...i dnt y it occurs as it used to run smoothly b4.... sys restore ,,, antivirus checking,, service packs,,spyware checking,,, turning to pio mode... nothing helps it... i hav winxp pro installed....i dnt knw wat to do??? plz suggest sumthng except formatting n reinstalling....
tweety_bird_bunny is offline
Old 19-02-2006, 02:32 PM   #2 (permalink)
Here is how you fix this problem dude. First, go into device manager. Next, go to IDE ATA/ATAPI controllers. Now, go to your secondary IDE channel and choose properties. Finally, go to the advanced settings tab and choose PIO only for "transfer mode". Obviously, you want to make sure that your CD rom is connected to the secondary controller first though. This will fix it for you. Once you are done, just restart your comp, and you will be good to go.
Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader.I am not responsible for what you do with it.
rajas700 is offline
