SDRAM has 168 pins and two notches at the connector, which prevents it from being used in a DDR SDRAM motherboard and vice versa. It comes mainly in PC66, PC100 and PC133; the bus speeds of the RAM in MHz.
DDR SDRAM has 184 pins and a single notch at the connector. It comes in speeds of PC1600 (166 MHz), PC1800 (200 MHz), PC2100 (266 MHz), PC2700 (333 MHz), PC3200 (400 MHz), and PC4400 (550 Mhz). The numbers represent the theoretical maximum bandwidth of the DDR SDRAM in Megabytes per second (MB/s). For example, PC2100 has a theoretical maximum bandwidth of 2100 MB/s.
See this for a DDR RAM Image:
www.ec.ingrammicro.de/jpg/3423799.jpg and this for SD RAM Image:
www.totalpc.it/images/SD-RAM.gif
Also see this from WIKIPEDIA:
www.en.wikipedia.org/wiki/DDR_RAM
Cheers n e-peace....
