Old 29-10-2004, 07:46 PM   #1 (permalink)
Default RAM..
i m having 128 ram just now...i want to upgrade to 256 ram...how much difference this is going to make to the performence of the system..
pls help...
thanks in advance guys...
atool is offline
Old 29-10-2004, 08:15 PM   #2 (permalink)
rohanbee's Avatar
Firstly what is the actual config of your ram?? 128mb ram @ 266mhz, 333mhz , 400mhz
Yes it will greatly improve working on programmes, games etc.....
I feel buying a memory module from a better rated company like kingston, corsair,mushkin also makes a difference.
Quote by Garfield'
rohanbee is offline
Old 29-10-2004, 08:21 PM   #3 (permalink)
also is it SD RAM or DDR Ram ? IF its SD then ur gonn ahave a tuff time finding another SD RAM and they are expensive due to their rarity.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 29-10-2004, 08:27 PM   #4 (permalink)
King of my own Castle
freshseasons's Avatar
How much it will make difference totally depends upon the fact ...like what actually you run...with windows 98 and bit of office tools its really not worth anything....But step into windows XP and gaming zone....and man are you in new world ?
256 mb ram will make a lot of difference ....thats where the eye candy of windows xp and most of the games live....Hmmmmm if you are talking Graphics animation...you are better off with 512 mb Ram or more pal... ..any way things finally depend on what you run ...!!!!!!!!! or intend to !!!!
freshseasons is offline
Old 29-10-2004, 10:04 PM   #5 (permalink)
thnks guys...
atool is offline
