Old 16-02-2006, 07:44 PM   #1 (permalink)
Default lsass.exe ERROR
My windows 2000 pro os often generates lsass.exe error and restarts. I am not able to find the reason behind it. Can anyone help me in this regard.
gamespy is offline
Old 16-02-2006, 08:18 PM   #2 (permalink)
Do you get any particular error number??? Pls describe the problem more clearly...
Regards....
shivaranjan.b is offline
Old 16-02-2006, 08:24 PM   #3 (permalink)
::cyborg::'s Avatar
hey does ur system restarts u have a spware problem then
::cyborg:: is offline
Old 16-02-2006, 08:25 PM   #4 (permalink)
::cyborg::'s Avatar
Old 16-02-2006, 08:25 PM   #5 (permalink)
::cyborg::'s Avatar
Old 16-02-2006, 08:38 PM   #6 (permalink)
Why are you posting the same post again and again?????
Old 16-02-2006, 08:45 PM   #7 (permalink)
bit
bit's Avatar
Default Re: lsass.exe ERROR
Your system is surely infected with worm, run a good antivirus such as kaspersky with up-to-date definitions and more importantly use a firewall while connect to internet. If you are already using a firewall then it means you have given access to that worm which is residing in your system.
bit is offline
Old 17-02-2006, 12:45 PM   #8 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Its the famous sasser worm! Get a good firewall. That should block it.. And scan with a good Anti Virus to remove it.
kalpik is offline
Old 17-02-2006, 02:15 PM   #9 (permalink)
I thought sasser worm only affects windows xp systems....
Old 17-02-2006, 02:50 PM   #10 (permalink)
kalpik's Avatar
I think it affects all NT based systems..
kalpik is offline
Old 17-02-2006, 03:50 PM   #11 (permalink)
It does affect the windows 2000 systems..
See here for the solution from microsoft.
Regards....
Old 17-02-2006, 06:42 PM   #12 (permalink)
kalpik's Avatar
Then i was right! Hehe
kalpik is offline
Old 18-02-2006, 09:44 PM   #13 (permalink)
Distinguished Member
anandk's Avatar
i may be wrong, but it could be the lovesan or blaster or sasser virus.
first run your virus scan (avast) at boot time or safe mode using deep-scan modes.
then download and use the latest sasser removal tool and sasser fixer tool (microsoft/symantec).
then patch up your pc with KB835732 patch.
use zone alarm firewall, when on the net. take windows updates or run the latest autopatcherxp..
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 18-02-2006, 10:24 PM   #14 (permalink)
readermaniax's Avatar
These links may help you:-
http://www.experts-exchange.com/Oper..._20958211.html
http://www.neuber.com/taskmanager/pr...lsass.exe.html
http://www.liutilities.com/products/...library/lsass/
http://process.networktechs.com/lsass.exe.php
http://ask-leo.com/what_are_lsass_ls...o_if_i_am.html
http://ask-leo.com/can_i_delete_lsas...vchostexe.html
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 18-02-2006, 10:33 PM   #15 (permalink)
TheRAVAN
Posts: n/a
Instead of all this sh** simply FORMAT your primary partition and reinstall properly...your system os F****d up..
Good Luck..
